why are my times so high? (searched)
Old Aug 7, 2005 | 07:46 PM
EFnerd's Avatar
Default why are my times so high? (searched)
so i ran my crx for the first time today (my first time at track)
here are engine mods....
B16a
S1 tranny
i/h/e
integra throttle cable
ACT dual friction clutch
aem fuel rail
BM fuel pressure gauge
CTR cams
Aem cam gears
stock ecu
today at the track my best run was 15.6@87mph.......
60ft was all about 2.446 or around there.....
at first i thought it was me sucking at driving but then i let a guy who knows how to drive and he ran worse than me....i played with itiming a bit but nothing.....
only things i can think of is:
it was hot liek 100
my header is dented hard and that makes my engine unhappy
i need to get it tuned
new fuel pump mabye?
my tires are shitty bald tstreet tires but still
others are always in 14's here on HT wtf....
o well always another day right?
Modified by crxnerd at 10:52 PM 8/7/2005
Old Aug 7, 2005 | 07:51 PM
Crx Jimmy's Avatar
Default Re: why are my times so high? (crxnerd)
my crx on azenis with a stock b16 I/h/e with smooshed dc header ran 14.9 at 99 mph, maybe its the tuning i was running a stock pwo.
Modified by Crx Jimmy at 12:07 AM 8/8/2005
Old Aug 7, 2005 | 07:53 PM
EFnerd's Avatar
Default Re: why are my times so high? (Crx Jimmy)
see thats about what i was expecting.....idk i know shes faster than this
Old Aug 7, 2005 | 08:08 PM
elrandeeto's Avatar
work on your launch 2.4 is pretty high , im having the same trouble with my ls crx i know whats hurting my times i just dont have the money to fix right now im on 17's with low profile tires my camber is way off horrible traction . what size rims and tires are you running , what tire pressure are you at , is your car lowered to where camber might be off . just a few things that could hurt your time . a 2.2 or better 60 ft should be possible with your car . usaully every tenth in your 60 ft ends up changing you 1/4 e.t.
by 2 tenths . Also is your car bogging when you launch you may need to launch higher . if your peeling out alot on your launch dont just dump the clutch kinda ride it alittle bit feather it also can mess with how much throttle you give it .
Old Aug 7, 2005 | 08:09 PM
Blaze45's Avatar
Brrraaaap!
Dude, dont worry to much. Skill plays a big part in times, but so do conditions. The other night in my B20 Turbo CRX I was pullin consistant 14.0 flats when most people with the same setup are running 12s and faster.( It was a cool 98 degrees out and I cant launch on street tires) But they have slicks and I highly doubt that their intake temps were the sweltering 150+ degrees that mine were... Plus they prolly have more wheel time then I do with their setup. Dont be to hard on yourself. On street tires my best since Ive turbo'd my car is 13.6@105 with much much more in it. But I havent gotten another chance to run my car cause its just been to hot, over 90 degrees out @ 10:30 @ night.... More wheel time and better track conditions will eventually fall in your favor and youll pull your 14.... Expriement with launch RPMs and tire pressure...
Good Luck
Blaze
Old Aug 7, 2005 | 08:11 PM
EFnerd's Avatar
Default Re: why are my times so high? (elrandeeto)
o my camber is fine i just got a kit in and got it all allinged the day of track...
im using 15 inch racing harts that weigh leik 11-12 lbs each....ive launched anywhere from 3.5k-6k.....6k worked the best it ...spun alot but got traction at same time...rpms stayed at about 5-6k then hooked up nice.....idk tho
Old Aug 7, 2005 | 08:21 PM
JDM Panda's Avatar
Crappie launch + bald tires + amateur driver= improvable times
-Panda
Old Aug 7, 2005 | 08:30 PM
elrandeeto's Avatar
Default Re: why are my times so high? (JDM Panda)
^^^^^ agree just keep practicing youll have better times
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnerd &raquo;</TD></TR><TR><TD CLASS="quote">stock p28 ecu... ...i need to get it tuned</TD></TR></TABLE>
Old Aug 7, 2005 | 09:20 PM
daidilus's Avatar
holey crap man...the ECU..stock P28, the fuel maps, the timing maps, and the rev limiter are all wrong for B!6, when my motor was stock..i beat the crap out of a car with a p28 running a b16, it is the ECU
and a smooshed header matters a lot also
Old Aug 7, 2005 | 09:26 PM
DohcVtecCrx's Avatar
stock p28 ecu</TD></TR></TABLE>
That is theproblem right there. Why on earth would you run a sohc vtec fuel and timing map on a b16a, and why would you do all the other mods and run a p28?
Old Aug 7, 2005 | 09:52 PM
EFnerd's Avatar
Default Re: why are my times so high? (DohcVtecCrx)
oops my bad...its the stock b16a ecu...i dont know what one that is....sorry idk y i was thinking p28....long day im sunburnt...
Old Aug 7, 2005 | 10:21 PM
K20EF8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">my crx on azenis with a stock b16 I/h/e with smooshed dc header ran 14.9 at 99 mph, maybe its the tuning i was running a stock pwo.
Modified by Crx Jimmy at 12:07 AM 8/8/2005</TD></TR></TABLE>
Is that a type 14.9@99
seems like a very high trap
Old Aug 7, 2005 | 10:28 PM
TurtleEF3's Avatar
Times can also be different depending on alltitude. Where I live times average out to around a full second slower than at sea level.
Old Aug 8, 2005 | 08:34 AM
Suck my DX's Avatar
sounds to me like ur just spinning ur tires....if u have bald tires that wont hook up...dont launch it so high ...u will get much better times with a hard roll off the line than if u sit there spinning....i mean 2.44 60 foot is horrible...lets say u pulled off a 2.2 60 ft...that would still put u around 15.3 -15.4...that is very slow considering ur set-up....work on driving and get that thing tuned...also dont mess with ur cam timing unless ur on a dyno...did u even redo ur base timing after u adjusted ur cams?...
Old Aug 8, 2005 | 07:47 PM
EFnerd's Avatar
Default Re: why are my times so high? (Suck my DX)
thanks for ideas guys....i only spun tires some times...i tried launching at 3k-6k entire day...i got about 12 runs in...and a guy that races his b16 hatch tried and he got same times as me....and even tho my tires were shitty bald street tires they had pro drags going on that day so the track was prepped good and sticky so i diddnt even spin much through gears....i just need to work on 0-60ft i guess.....i prolly wont race at the track for awhile...but i know this crx is at least a 15sec flat car....just need work
Old Aug 8, 2005 | 08:16 PM
Dancing is Forbidden's Avatar
How do I cut 2.0's with street tires in a stock LS CRX?
Old Aug 8, 2005 | 08:58 PM
EFnerd's Avatar
up for more answers
Old Aug 8, 2005 | 09:19 PM
EF9SIRJeff's Avatar
DUDE you got something Up with your stuff
I run a D16A6 with intake, exhaust, headers, highflow cat, light Fly and stage 2 clutch
i have run a 15.8 at 86 Mph
at 5400 feet corrected altitude
99 degrees outside and prolly hotter on the track
dont know what to tell ya
Oh also ran a 2.2 second 60 Foot
Old Aug 8, 2005 | 09:40 PM
RangerDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnerd &raquo;</TD></TR><TR><TD CLASS="quote">up for more answers</TD></TR></TABLE>
Whats the track elevation?????????
And yeah if you havent ran at the track before with that car times will improve. Its all in the first 60 feet.
Old Aug 8, 2005 | 09:58 PM
EFnerd's Avatar
Default Re: why are my times so high? (RangerDan)
i dont know track elevation...it was in fargo ND so yea....there was a dood with a stock b16a EF with slicks runnign low 15's all day and my buddy ran a 15.0 with his b16 ef hatch all gutted and when he went to washington on the coast he said he was beating other hatches that said they ran mid 14's....so mabye elevation has a lil bit...ill just practice driving for now...i can shift really good just the launches i have trouble with....thanks guys
Old Aug 8, 2005 | 10:07 PM
RangerDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnerd &raquo;</TD></TR><TR><TD CLASS="quote">i dont know track elevation...it was in fargo ND so yea....there was a dood with a stock b16a EF with slicks runnign low 15's all day and my buddy ran a 15.0 with his b16 ef hatch all gutted and when he went to washington on the coast he said he was beating other hatches that said they ran mid 14's....so mabye elevation has a lil bit...ill just practice driving for now...i can shift really good just the launches i have trouble with....thanks guys </TD></TR></TABLE>
Well I looked it up and your around 900 ft elevation which doesnt hurt your time at all. Better tires for sure the other thing is, hows your suspension?
Old Aug 8, 2005 | 10:36 PM
EFnerd's Avatar
suspension is nothing special at all right now....my chassi is stiff with strut bars and a roll cage but im in process of buying better suspension...its stock struts on neuspoeed springs right now....money is a prob
Old Aug 8, 2005 | 11:03 PM
cmyrex's Avatar
Do you mean it was 100% outside im pretty sure you could shave some tenth's of a second when it cools down. You will get better man i Ran sh#tty my first time at the track you will get better.
Old Aug 8, 2005 | 11:08 PM
EFnerd's Avatar
Default Re: why are my times so high? (cmyrex)
it must just be my driving from 0-60ft and my bald *** tires.....ill get it sooner or later...thanks guys!!
slowsleeper
Apr 11, 2004 11:54 PM
hondacru27
Dec 11, 2003 05:43 AM
essinem4130
Jun 23, 2003 05:03 PM
b16_incarnate
Oct 17, 2002 11:08 AM
InTeGrA B18b1
Sep 25, 2002 08:19 PM
