Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
ITR and Race Slicks...how do you get them to fit???
Old Aug 7, 2005 | 04:59 PM
J28S's Avatar
New User
Default ITR and Race Slicks...how do you get them to fit???
OK you gurus... I got a set Hoosier Race Slicks (23x8.5x15). What type of offset is needed for the wheel? Can you get away with bigger spacers and longer studs?
Trying to figure this out...
EXTRA QUESTION:
Question 2: how much PSI do you start with these tires? What is the optimal temperature? Would the 9.5" be better? Thanks again.
Modified by J28S at 3:47 PM 8/8/2005
Old Aug 8, 2005 | 06:08 AM
philstireservice's Avatar
Default Re: ITR and Race Slicks...how do you get them to fit??? (J28S)
well .....they will most likely rub on the rear with 15mm spacers and a 42mm offset with longer wheel studs. Try 25mm spacers and 42mm wheel....no rub then, but you will have to use a bolt on spacer. Or go with a 35mm offset wheel and 15mm spacers...should be no rub then also.
Old Aug 8, 2005 | 06:30 AM
J28S's Avatar
New User
Default Re: ITR and Race Slicks...how do you get them to fit??? (Maxx44)
Thanks - just what I needed to know!!!
Old Aug 8, 2005 | 07:18 AM
Honda318dx's Avatar
Slicks aren't allowed in HC1
Old Aug 9, 2005 | 05:22 AM
just4fun's Avatar
Try 26 psi hot
Old Aug 9, 2005 | 05:23 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: ITR and Race Slicks...how do you get them to fit??? (just4fun)
as RJ would say "BFH will make'm fit"
Old Aug 9, 2005 | 06:46 AM
Renegade's Avatar
Default Re: ITR and Race Slicks...how do you get them to fit??? (MMsportsRexSi)
I saw an Integra running 235s in HTCC, not sure which car but it runs in USTCC. It had on spacers that looked like one inch or bigger. I currently run 225 on a 7.5 wheel with +43offset on my ITR, I have to use 5mm spacers and longer studs (otherwise I only get 5 turns on the lug nut) so it does not rub.
blackhawksfan18
Jan 8, 2014 02:55 PM
Max500
Jul 1, 2007 03:27 PM
808jdm_profileEG6
Apr 16, 2007 06:05 PM
Toda Built
Jan 30, 2004 03:53 PM
