need help with my zc
Old Aug 7, 2005 | 04:28 PM
luker's Avatar
Default need help with my zc
i got this problem with my dohc zc. I dropped a 92 zc in my 90 crx, ok now on my harness there is 9 wires for the dizzy, for the jdm dizzy only has 7 , 2 for the cam sensor and the rest are on the other plug. well i have the 2 blue wires left that i can't hook up, so i bought a exhaust cam sensor , pluged those 2 blue wires and i'm running in safe mode, i can't rev my car past 3000 rpms can someone tell me what i did wrong ?
Old Aug 7, 2005 | 06:31 PM
Sikocivic's Avatar
Default Re: need help with my zc (luker)
You need to replace the dizzy with one from a 88-89 Integra. It has the correct sensors in it to allow the motor to run right. The one you have is OBD1, you need OBD0
Old Aug 8, 2005 | 11:39 AM
luker's Avatar
i did change my dizzy with a 88-89 integra and it doens't work, i think now i'll just go and get a engine harness and ecu for the engine
Old Aug 8, 2005 | 03:02 PM
MagnaniEG6's Avatar
Default Re: (luker)
Check this link out! It should answer your question:
http://www.thezcr.com/forums/showthread.php?t=5578
stickman78114
Feb 21, 2010 09:37 AM
twentyhurtz
May 21, 2009 06:17 AM
bonestock91
Jul 16, 2006 05:48 AM
luker
Jul 24, 2005 11:24 AM
stw88crx
Mar 15, 2005 07:07 AM
