RC 310's dont fit...
Old Aug 7, 2005 | 02:12 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default RC 310's dont fit...
Hey all. I recently got RC 310cc injectors from someone for a good price, the problem is they didn't come with the replacement o-ring washers that they sit into. So, my 310cc injectors wont fit into the stock manifold holes.... can you make these fit? Maybe some lube or something? I have heard that the replacement ones RC sends you have a tendencey to break.
Any ideas?
Old Aug 7, 2005 | 02:46 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: RC 310's dont fit... (JDM_Ej)
Bump... someone has done this...
Old Aug 7, 2005 | 04:15 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Yea, I searched... nothing?
Old Aug 7, 2005 | 04:23 PM
SpdFrk's Avatar
U don't need any lube or anything to make them fit, they should just slip right in. Since u said they didn't come with the o-rings for the intake manifold side are u using your stock ones?
Old Aug 7, 2005 | 04:26 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: RC 310's dont fit... (SpdFrk)
Trying to use the stock ones yea, but the RC's are bigger than the stock, so the factory O rings have a slightly smaller opening for the injectors to sit it. I dont want to trim these for fear of a nice fuel leak.. if I use some lube, will I be able to "force" them in there?
Old Aug 7, 2005 | 04:34 PM
SpdFrk's Avatar
Yeah, i wouldn't trim the o-rings, try lubing them up and slipping them on. If that doesn't work see if u can the RC ones.
Old Aug 7, 2005 | 07:44 PM
Garcia-Racing's Avatar
Grind the outsides of the o rings on a bench grinder carefully.
Old Aug 7, 2005 | 08:10 PM
omiehomie's Avatar
Default Re: (Garcia-Racing)
i had the same problem and it was such a bitch to get them in
patience and some WD 40 and you should be able to get them in.
where and how much are the ones from RC?
Old Aug 7, 2005 | 08:24 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: (omiehomie)
Ill try lots of WD40 and some patience and see if that works. As for the RC rings, my friend broke his installing his 550's. Said they're pretty crap? I can't find them though, I'll have to call RC and see if they sell them seperatley if thats the case.
Old Aug 7, 2005 | 10:39 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: (JDM_Ej)
Im gonna try and squeeze them into the stock rings on the intake manifold.... anyone else had this problem before?
Old Aug 8, 2005 | 07:03 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
bump..?
Old Aug 8, 2005 | 11:42 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
one more bump just for the helluv it.
Old Aug 8, 2005 | 01:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Im gonna try and squeeze them into the stock rings on the intake manifold.... anyone else had this problem before?</TD></TR></TABLE>Yes, I shaved them, didn't leak.
DualCamEJ
Apr 9, 2010 05:03 AM
allinone07860
Feb 25, 2007 10:10 PM
JDM_Ej
Aug 8, 2005 12:32 PM
b20ek
11
Jun 29, 2003 09:18 PM
SiRkid
Aug 24, 2002 07:20 PM
