First time to run 1/4 mile in my car. fully built 14 psi 350 hp. do my numbers look where they shoul
ive been running 1/8th because there is a close track but i made and hour and a half drive to find out what she could do. my car is built with a rev hard kit and a sc61. still have small piping. 2.25 ic piping and 2.5 exh. well here are my numbers so im just wanting to know if im running slow or about where i should be. 353 whp, 249 tq.
60' 1.957
330 5.424
1/8 8.233
mph 87.54
1000 10.649
1/4 12.677
mph 111.96
60' 1.957
330 5.424
1/8 8.233
mph 87.54
1000 10.649
1/4 12.677
mph 111.96
last year my car made 380whp and i ran consistant 11.4-11.6 at 124-126 mph if that helps.....B16 with SC44
I know my car was making around 350whp (injector duty cycle) and I was going 11.70's/80's @ 119-121mph consistently. Your e.t. and MPH seem to not reflect 350whp. What is your vehicle weight?
Phil
Phil
my car is full interior just like buying from the dealer. im not sure what a integra weighs i think 2800. i thought my times were pretty good. but guess not where they should be. i dont think im getting a good burn out at all. i read about these 2nd gear burn outs and im going to try it next time i go. maybe that will help me some.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbosi »</TD></TR><TR><TD CLASS="quote">my car is full interior just like buying from the dealer. im not sure what a integra weighs i think 2800. i thought my times were pretty good. but guess not where they should be. i dont think im getting a good burn out at all. i read about these 2nd gear burn outs and im going to try it next time i go. maybe that will help me some. </TD></TR></TABLE>
are you running slicks? if you are what size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote"> Your e.t. and MPH seem to not reflect 350whp. </TD></TR></TABLE>
I agree. Even in a full weight Integra they seem pretty low.
im not guessing on my hp my car was tuned on the dyno. 353 whp and 249 tq. how much does a integra weigh.
how big of a difference will me feathering the clutch as to dropping make. i bog pretty bad off the line and dont catch like i should.
in your sig it looks like we have a very similiar time. yeah i dont understand my car. it feels very fast but it just seems like it should be faster. maybe i just cant drive. maybe my car is slow. i dont know. any input would help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbosi »</TD></TR><TR><TD CLASS="quote">in your sig it looks like we have a very similiar time. yeah i dont understand my car. it feels very fast but it just seems like it should be faster. maybe i just cant drive. maybe my car is slow. i dont know. any input would help.</TD></TR></TABLE>
Your 60' is the only thing that needs improving really. The rest of the run is on point w/ a normal high 12 sec. run. I just can't see why your MPH is so low? Even being 2800lbs. I still think the trap should be up around 117-118.
Phil
Phil
Shift faster, keep the rpm's up even if you have some wheel spin, hold it in gear till redline....
Really without seeing you drive we can only tell you that 350whp will move 2800lbs faster than that.
there is a lot of factors that play into it, what about suspention, tranny gearing, launch RPM plus what ever else was already mentioned, i think most of all what you need is seat time.
by the way, you will find that most people here are running stock axles with no problem.
My car made 322whp and 221wtq on 12psi, weighing 2750w/driver i have run consistent 11.90's-12.0's and trapping anywhere from 111-114mph on that hp level. To me your mph is right for your weight, you say 113.6 is your best then thats right about where i am only you weigh a little more with an integra. If you can cut 1.7 60fts then no doubt you can run some low low 12's for sure.
Adi Radoncic
Sep 1, 2002 11:37 PM
