JDM B16 (hmotorsonline92-95) with 99 si ECU and Wiring harness HELP IMMEDIATELY
Old Aug 7, 2005 | 10:58 AM
BLKCivicPorscheStyle*'s Avatar
Default JDM B16 (hmotorsonline92-95) with 99 si ECU and Wiring harness HELP IMMEDIATELY
I have been trying to do this swap in a 98 civic EX I know that the motor is OBD1 and the harness ECU are OBD2. Everything is going fairly smooth with just plugging everything up. I have a 99 si motor that is blown to take sensors and things from but I ran into one problem which i searched and found that its a crank fluctuation sensor. That particular sensor isnt on the 92-95 JDM b16 can i run without the sensor at all or will the OBD2 P2T ecu look for the readout and **** everything up? can i expect any more problems this is my first swap so bare with me
Old Aug 7, 2005 | 01:09 PM
Default Re: JDM B16 (hmotorsonline92-95) with 99 si ECU and Wiring harness HELP IMMEDIATELY (BLKCivicPorsche
bump
Old Aug 7, 2005 | 01:30 PM
andyjt's Avatar
use the obd2 oil pump of the 99 si motor and the sensor is right in it..
Old Aug 7, 2005 | 09:18 PM
Default Re: (andyjt)
yeah thats sort of what we were planning is there anything i need to do special im worried that swaping the two will mess up the timing and something could go very wrong.
Old Aug 8, 2005 | 05:26 PM
bump
Old Aug 8, 2005 | 06:23 PM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyjt &raquo;</TD></TR><TR><TD CLASS="quote">use the obd2 oil pump of the 99 si motor and the sensor is right in it.. </TD></TR></TABLE>
japdunce
Feb 22, 2013 11:33 AM
titan2hell
May 17, 2011 08:08 PM
krazyEG
Southeast (Sales)
Dec 1, 2008 11:59 AM
jelatime
Apr 21, 2008 07:07 PM
solk1dd
Aug 17, 2004 06:27 PM
