B16A1 or B16A2/A3
Old Feb 21, 2002 | 01:21 AM
gtracer's Avatar
Default B16A1 or B16A2/A3
This is my first message and first I want to say hi to all
I am planning to get a B16A this summer. I'm not sure which one to get though. A1 has 10 less hp. I guess A1 has a smaller throttle body (?) and intake manifolds look different. Most probably A1s have more miles on them. please correct me if I'm wrong. So, actually what is the difference between them and does it really worth paying one grand more for the B16A2/A3?
Thanks..
Old Feb 21, 2002 | 06:28 AM
Spade's Avatar
Default Re: B16A1 or B16A2/A3 (gtracer)
Compression ratio, age, quality of craftsmenship, age, the year of your car (not legal to put an older engine into a car, age, possiblity of parts broken on older engine/tranny, age, <FONT COLOR="red">EDIT:</FONT>(I forgot some stuff of course) cams, age.
The 16A2's and A3's are newer engines however, if you feel you are going to completley rebuild the engine with goodies anyway and your chasis is older then the 16A1's then get a A1 and spend the extra money on goodies for the engine rebuild it will most likely need.
[Modified by Spade, 7:29 AM 2/21/2002]
Old Feb 21, 2002 | 03:50 PM
gtracer's Avatar
Default Re: B16A1 or B16A2/A3 (Spade)
Thanks for the info & suggestions Spade. Age is a BIG problem I guess
btw the engine will go into an 88 crx
regards
Old Feb 21, 2002 | 04:01 PM
SlowB16's Avatar
Wait a minute. You cant put an engine out of a car that is older than your car?? Is this just a law in California or something??
Old Feb 21, 2002 | 04:12 PM
gtracer's Avatar
Default Re: B16A1 or B16A2/A3 (SlowB16)
I don't know but it would be better if you check your local laws. That's what I'll do before I start buying things.
Old Feb 21, 2002 | 05:54 PM
Kamin's Avatar
in california
the engine must be same year or newer.
and if its going into an 88crx?
get a first gen b16!
there a dime a dozen and you wont have any problems dropping it in.
Old Feb 22, 2002 | 07:52 AM
SPORT INJECTION's Avatar
california has alota dumb azz laws huh?
Old Feb 22, 2002 | 09:19 AM
Spade's Avatar
Default Re: B16A1 or B16A2/A3 (99MilanoRedSi)
&lt;------------look here.
California Air Resouces Board (CARB) California Highway Patrol (CHP)
Type 56
Engine Machining & Assembly
Mar 31, 2016 11:46 AM
maintain
May 20, 2008 09:12 PM
germanEE8
Dec 30, 2003 07:07 AM
Root79
Jul 7, 2003 10:47 AM
