Spark plug wire blowing off
Old Aug 7, 2005 | 10:12 AM
1.8EG-T's Avatar
Default Spark plug wire blowing off
I have noticed that my spark plug wire likes to blow off after getting on it pretty hard...It happened with stock wires, and now it is happening with the autozone cheapies...can anybody fill me in as to why this would happen?
Old Aug 7, 2005 | 03:21 PM
drdisco69's Avatar
Default Re: Spark plug wire blowing off (1.8EG-T)
Sounds like too much blowby, causing lots of crank case pressure which is leaking past the spark plug grommets and popping off the wires. Check the PCV valve, if it's stopped up it won't release the pressure. Otherwise, glue the wires down and rebuild the motor when you get the time.
Old Aug 7, 2005 | 03:46 PM
1.8EG-T's Avatar
Default Re: Spark plug wire blowing off (drdisco69)
No, I think you are in teh wrong area...the first time it occured was with a b18b, and it happened a few times, the second is witht he built, less than 2000 miles b18c. I have a catchcan setup on there, removing the pcv valve and the black box on the back...kinda eerks me though...any more ideas?
Svell
Mar 31, 2011 12:57 PM
MyHotsh
Jun 5, 2009 04:27 PM
nix94delsol
May 1, 2009 01:16 PM
exile29
Oct 6, 2006 08:53 PM
Yokohama
12
Jul 2, 2003 12:59 AM
