CRX Flywheel Spline count ( diffrence in DX & SI )
Old Aug 7, 2005 | 09:53 AM
explictness's Avatar
Default CRX Flywheel Spline count ( diffrence in DX & SI )
Friend has a 89 crx Si flywheel and i have a crx dx, i was wondering if his flywheel would work on my car. my car is all stock just to let everyone know.
Had to rephrase because someone gave me wrong info (ERIC u DUMMIE)
Modified by explictness at 11:03 AM 8/7/2005
Old Aug 7, 2005 | 09:54 AM
crxgator's Avatar
Default Re: CRX Flywheel Spline count (explictness)
there are no splines on the flywheel...splines are on the transmission and clutch disc...and they would be different on years 88 compared to 89-91...
Old Aug 7, 2005 | 11:59 AM
31flavorscivic's Avatar
Default Re: CRX Flywheel Spline count (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">there are no splines on the flywheel...splines are on the transmission and clutch disc...and they would be different on years 88 compared to 89-91...</TD></TR></TABLE>
That has to do with the splines on the input shaft of the transmission counting 21, whereas everything from 1989-at least 2000 is 20. However there is another problem which cost me some cash and I will explain so you dont do the same.
I had a massive-*** problem with clutches and flywheels earlier. An '89 flywheel will <u>NOT</u> bolt with a clutch from 1990-2000. I'm not sure about a clutch from 1988.
It's all in the diameter of the clutch surface. Let me find the diagram and I will post up.
edit:
http://bumrockerforlife.mine.n...h.pdf
Modified by 31flavorscivic at 2:12 PM 8/7/2005
Modified by 31flavorscivic at 2:13 PM 8/7/2005
Modified by 31flavorscivic at 2:14 PM 8/7/2005
Old Aug 7, 2005 | 12:09 PM
Default Re: CRX Flywheel Spline count (31flavorscivic)
alright cool thx.
Old Aug 7, 2005 | 09:19 PM
^^ in order to buy a new Centerforce stage 2 clutch for my car, I had to steal the flywheel off of my 1994 civic CX d15b8 engine, because they don't make any for my 1989 flywheel.
Old Aug 7, 2005 | 11:29 PM
Deo's Avatar
Deo
So the exact model (hf, dx, si) never has anything to do with it, only year?
I wish Advance had this stuff figured out, most of the transmission stuff was just called a day and listed as the same for all years.
Old Aug 8, 2005 | 05:22 AM
EP3_05's Avatar
Default Re: CRX Flywheel Spline count (Deo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deo &raquo;</TD></TR><TR><TD CLASS="quote">So the exact model (hf, dx, si) never has anything to do with it, only year?
I wish Advance had this stuff figured out, most of the transmission stuff was just called a day and listed as the same for all years.</TD></TR></TABLE>
Correct, the transmission model does not matter only the year.
ls19integra95
May 4, 2007 03:21 PM
hondacivic90zc
Mar 21, 2007 07:19 PM
vbspec
Jan 16, 2007 10:29 AM
denzel
Feb 19, 2005 08:03 AM
Hybrid CRX
Jul 15, 2002 06:26 PM
