I want a used 4.400 FD!
Old Feb 20, 2002 | 11:53 PM
austrian type-R's Avatar
Default I want a used 4.400 FD!
Yes, It seems I´m the only one who thinks about going from JDM FD to USD FD, hehe
It is just a mind at the moment, but I think when my ITR is turboed I want a faster car. I realy think the USDM final drive makes me not slower, cause I can make a bit more boost in 1st and 2nd gear, cause of the longer engine load.
I know a punch of people have installed a JDM fd and I wonder what you do with you stock fd. I guess you have it somewhere in the garage or so
What do I need beside the 4.400 gear. Any bearings and /or other gears?
Who can help me out.
[Modified by austrian type-R, 9:54 AM 2/21/2002]
[Modified by austrian type-R, 9:55 AM 2/21/2002]
Old Feb 21, 2002 | 03:44 AM
Willard's Avatar
Default Re: I want a used 4.400 FD! (austrian type-R)
Don't forget about the 4.20 final drive that the LS tranny has in it.
I guess you would need the same parts as the 4.785 install would require... https://honda-tech.com/zerothread?id=119053
Will
-who wished he had a 4.785 for sale...
Old Feb 21, 2002 | 03:48 AM
Default Re: I want a used 4.400 FD! (Willard)
Thanks.
But I don´t get it exactly if I only need this 4.400 gear or do I need some parts beside the fd like shafts, etc. to make a complete tranny conversation to 4.400.
I want to keep my stock 1, 2, 3, 4 and 5th gear.
Common`anyone has to know.
oh yeah, how much would such an convert cost, when I take the parts used? Of course in good shape
[Modified by austrian type-R, 1:49 PM 2/21/2002]
Old Feb 21, 2002 | 03:54 AM
Willard's Avatar
Looks like 6 pieces are used in the 4.785 conversion.
-2 needle bearings
-final drive ring
-final drive pinion
-a gear of some sort
-and the item in the little bag near the bottom (middle) of the picture
You will be able to keep your 1st thru 5th.
Not sure how much to perform the swap. Most any good transmission place should be able to perform the work.
Will
Old Feb 21, 2002 | 04:06 AM
I meant what can someone charge me for the used parts.
Somebody knows the exact names of this 6 parts?
What is a gear of some sort?
[Modified by austrian type-R, 2:06 PM 2/21/2002]
Old Feb 21, 2002 | 05:27 AM
Dr Pooface's Avatar
You'll need a :
USDM countershaft
USDM first gear
USDM FD (4.4)
2 needle bearings (they go between the shaft and first gear)
At least thats what I took out when I installed my ATS, so I assume it's what you need .
Old Feb 21, 2002 | 05:36 AM
Default Re: I want a used 4.400 FD! (Dr Pooface)
Thanks
Can you explain me, why I would need a USDM 1st gear? The ratio of 3.230 is the same on JDM and USDM spec.
Do you have those parts for sell?
Old Feb 21, 2002 | 05:40 AM
AssPenny's Avatar
I sold my counter shaft, 4.4 fd, and bearings for 100 bux. Yea I know I could have gotten more for it, but oh well, I helped out a fellow R owner.
Old Feb 21, 2002 | 05:43 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Thanks
The gear ratio is the same but the countershaft is a different diameter, so the JDM gear wont fit on a USDM countershaft and vice versa.
Old Feb 21, 2002 | 05:48 AM
Default Re: I want a used 4.400 FD! (Dominic Toretto)
I know I´m not a tranny expert (not yet) but why does then 2nt-5th gear fit? just confused
Old Feb 21, 2002 | 05:49 AM
b00st-0wnz's Avatar
If you look at a pic of the countershaft, each gear has different splines that it fits on, 1st gear is the only different one, the rest are the same between USDM and JDM.
Old Feb 21, 2002 | 06:01 AM
Ausmith's Avatar
I've got a slightly used complete set.
Old Feb 21, 2002 | 06:57 AM
jeff652's Avatar
Default Re: I want a used 4.400 FD! (Ausmith)
check your PM
Old Feb 21, 2002 | 07:05 AM
Black R's Avatar
25 Year Member
I'll straight up trade you my 4.4 for your 4.785..... Used less than 10k miles.....
itr1244
Dec 12, 2019 02:11 PM
migs
Oct 27, 2006 10:39 AM
itr1244
Jun 16, 2006 06:04 PM
Thrillhouse
Jun 29, 2004 11:41 PM
Teal95Coupe
Oct 27, 2002 01:06 AM
