98 Accord 4 cyl wouldn't start. Waited 15 minutes then ok
Old Aug 7, 2005 | 07:39 AM
khutchinson's Avatar
Default 98 Accord 4 cyl wouldn't start. Waited 15 minutes then ok
Went to start and I let go of the key just a little too soon and the car stalled.
Then it would turn over but no ignition.
Thought fuel pump or filter.
Went to call a tow truck.
Came back 15 minutes later and tried it again and it started fine.
I was thinking maybe the computer got confused by the stall and wasn't allowing ignition. AFter 15 minutes it reset itself.
Is this reasonable or do I have a flakey ignition switch etc?
Thanks
Ken
Old Aug 7, 2005 | 07:40 AM
Beach Accord's Avatar
you could have waited 5 seconds and it would have started, just a bit of a flooded cylinder probably.
Old Aug 7, 2005 | 12:59 PM
SlowAccordEX's Avatar
Default Re: (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">you could have waited 5 seconds and it would have started, just a bit of a flooded cylinder probably.</TD></TR></TABLE>
Yup. While learning stick on mine I flooded it a few times. About 10-15 seconds later it would fire right up. Was quite embarassing actually.
Old Aug 7, 2005 | 04:22 PM
huy-z's Avatar
Default Re: 98 Accord 4 cyl wouldn't start. Waited 15 minutes then ok (khutchinson)
there may be a problem with your main relay, is your loc hot. my girls car does same thing, when it get 100 or higher car won't start check out this site
http://n479ad.doubleclick.net/adi/ab...r0J20SA3o7o287
explains a little more
huy-z
Old Aug 7, 2005 | 04:54 PM
I don't think it was flooded.
After it wouldn't start at first I looked under the hood to check for obvious things like an HT wire fell off or fuel line cut. That must have taken 60 seconds or so. Also I tried starting it with the pedal all the way to the floor (does that still do anything?). It didn't even sputter.
Would the starter run if there was a problem with the main relay? It was a warm day (80F), but the car hadn't run yet that day.
Old Aug 7, 2005 | 08:55 PM
Stripped Honda's Avatar
99-0104
Default Re: (khutchinson)
it is your main relay just buy another one and install it ... i install about 4-5 of them a week in accords ... the problem with the main relay is the soder joints get damaged and it wont make contact when it is hot ... dont bother with the resodering because you really dont want to get stuck somewhere without a way to get home and besides it only cost around 50 bucks
Old Aug 7, 2005 | 09:04 PM
deserthonda's Avatar
if car dies as soon as u let go of key u could have a bad electrical part of ignit switch ....i am not 100% sure but i think that there is a recall from honda on those ..u might want to call dealer to verify ...
1yesfan
Apr 6, 2016 03:50 PM
dznutz1886
Aug 1, 2011 03:18 PM
98accordlxhmmn
Oct 4, 2010 06:18 AM
cefirott45
Feb 14, 2008 05:34 AM
mixmastacg123
Oct 12, 2006 02:37 PM
