trailing arm bushing (PIC)
Old Aug 7, 2005 | 07:34 AM
thomst4R's Avatar
Default trailing arm bushing (PIC)
Can someone tell me what I highlighted in paint? the blue and red lines. Which one is the bushing? Can someone tell me if that crack that I pointed out is bad?
Thanks
Old Aug 7, 2005 | 07:42 AM
pdiggitydogg's Avatar
Its a trailing arm bushing...the whole thing comes as 1 unit. You can buy a replacement set of mugen mounts at king motorsports for $115.
Do not get those urethane ones, if youre replacing.
Search for trailing arm bushing and you will come across how to remove and install new ones yourself w/o a press.
Old Aug 7, 2005 | 07:45 AM
thomst4R's Avatar
Default Re: (pdiggitydogg)
both of them make up the bushing? I'm really broke (-$200) so i was wondering if I could just put that in there or is that crack in the bushing going to destory me. I bought that arm b/c mine was bent bad.
Old Aug 7, 2005 | 07:54 AM
it depends on how bad the crack is, but from what I see, I wouldnt put it on there.
Try some window weld globbed on to seal it up as a temp fix.
efyou999
Suspension & Brakes
10
May 28, 2010 09:12 AM
chatham
May 20, 2006 10:18 PM
92integraVTECgsr
Feb 11, 2005 04:00 PM
ragejed
Jun 16, 2003 04:05 PM
