Bumpstops?
My CRX is on AGX Shocks with Ground Control Coilovers... I didn't cut my bumpstops and my car is pretty low so the ride is kinda ruff... I'm thinking the car is "bumping" off the bump stops. How much of a difference in ride quality could i expect if i were to cut my bumpstops in half?
thanks for the help...
Well It depends on how low you have them. Usually you should cut them in half whenever you lower you car. Either way you should call ground control and ask what they recommend you cut for your drop. It will help it out some though because you will have more of the shock to use before it hits the bumpstop.
im riding no bumpstops on stock shocks and its fine no problems with ride it doesnt have a bouncy ride at all pretty stiff lowered with arospeed coilovers witch were pretty cheap and worth every penny
From: A place where stupidity runs rampant aka NorCal
You can get custom bumpstops from Truechioce, they are made to go with konis. I believe they have all custom sizes, and stiffness choices such as soft, medium and hard. They are pretty inexpensive too, somewhere like 10 bucks each.
-Todd
-Todd
