are all Coilover springs the same diameter?
I have GAB coilovers but the springs rates are too stiff. I don't know where to order GAB coilover springs from so will Tein or any other fit these dampers?
You need to meanure the inside diameter and also see if the diameter stays the say throughout the spring. The three most common ones we see here are the industry standard 2.25 inch, 60 mm, and 2.50 inch. The 2.50 inch is by far the most commone but there are any muber of otehrs so you ill need to measure what you have and your spring perches to know what you have.
Jer
Jan 1, 2004 11:35 AM
