Stock ITR front shock vs Stock GSR/LS front shock
Old Aug 7, 2005 | 02:20 AM
Spec R's Avatar
Default Stock ITR front shock vs Stock GSR/LS front shock
Stock ITR front shock vs Stock GSR/LS front shock?
Does anyone know the differences between the two, if any, other than the stiffer top hat bushings?
stock itr spring (is a little more than half an inch lower than GSR/LS) has 246 lb/in and stock LS/GSR has 217lb/in for their spring rates for reference...
Old Aug 7, 2005 | 05:11 AM
RagingAngel's Avatar
Default Re: Stock ITR front shock vs Stock GSR/LS front shock (Spec R)
supposedly 300% increase in rebound or was it compression dampening....?
It's been 10yrs ( ) since I first watched that video of the 96spec R ripping around....
While I can't quote the exact figures, there is a difference between the valving on an ITR damper vs. its more luxurious brothers.
Old Aug 7, 2005 | 07:14 AM
Spec R's Avatar
Default Re: Stock ITR front shock vs Stock GSR/LS front shock (RagingAngel)
damn. i figured there was a difference, but not that much of a difference, even if you're estimating. I have that best motoring dvd, i'll give it a lookover...
i cant imagine the extra 30 lb/in increase in spring rate be too hard for the stock shock to handle, given many people use stock shocks on springs (of course with limited performance) with double or more the spring rate of stock springs....
Loyalty2086
Oct 30, 2009 10:15 PM
Spec R
Suspension & Brakes
Aug 8, 2005 05:43 PM
nugget8000
Jul 28, 2001 05:31 AM
