sunroof stuck open! rain is coming!
Old Aug 6, 2005 | 11:43 PM
spiffy's Avatar
Default sunroof stuck open! rain is coming!
i need some quick answers, it's gonna rain any day now and my sunroof is stuck open. it opened and a half hour later the switch does nothing. i checked the fuse, i tried pulling the thing by myself... yeah right. there is supposed to be a gear i can crank to close it manually but i can't find it. i could care less if the sunroof doesn't work, i just don't want to have a fish tank for a car. i have the thing wrapped with poly and duct tape, looks pathetic. also i fear it's a good target for thieves. it's a 90 civic si fyi. thanks!
Old Aug 6, 2005 | 11:48 PM
BiG Chris's Avatar
there is a tap near the dome light you can pop open and its a allen head in there that you use to close it
Old Aug 7, 2005 | 12:01 AM
crx-treme's Avatar
Default Re: (BiG Chris)
what he said^
if u have the oem tool kit, theres a tool in there for manual sunroof operation.
Old Aug 7, 2005 | 08:21 PM
spiffy's Avatar
Default Re: (crx-treme)
i'll give it a shot. pardon my lack of vocabulary; but what is a tap? is it a cap? or is it one of those two black plastic lever looking things? i'll just have to see for myself. thanks!
Old Aug 7, 2005 | 09:32 PM
ImportHatch's Avatar
Default Re: (spiffy)
Just go look by your dome light. Should be pretty obvious.
Yager-
Old Aug 7, 2005 | 09:34 PM
91_CRX's Avatar
Default Re: (
Here is a write-up for a bad switch. Try it.
https://honda-tech.com/zerothread?id=1218089
Scroll down to see my write-up. Lots of pics.
Old Aug 8, 2005 | 07:14 AM
spiffy's Avatar
Default Re: ( (91_CRX)
that is a nice write up, but i found the problem. it finally rained and i had to drive to work. my poly and duct tape didn't hold up at highway speeds. rain is dripping in.... nice. while driving i noticed my wipers weren't working either. when i got to work i went to check the wiper fuse and noticed there is a fuse-relay for the wipers + sunroof. who knew there was 2 fuses for the sunroof. well i guess i should look a little closer next time. problem solved, little damage done. thanks guys.
serr38
May 10, 2009 03:39 PM
wasssup
Paint and Body
Aug 20, 2008 02:00 PM
SamN
Apr 26, 2007 04:45 PM
KyleVA
Jan 23, 2007 06:33 AM
Boarderx192
Aug 30, 2005 05:13 AM
