87 civic what d series motor can i upgrade too?
Old Aug 6, 2005 | 07:21 PM
Spence's Avatar
Default 87 civic what d series motor can i upgrade too?
Hey guys im looking at buying a 87 civic for a daily driver but it has a blown headgasket on a 249,000 mile motor so i was looking to upgrade to a better d series tell me what will fit not fimiliar with the pre 91 swaps
Thanks
Spencer
Old Aug 6, 2005 | 07:26 PM
JDN169's Avatar
Default Re: 87 civic what d series motor can i upgrade too? (Spence)
D16A1 from a 1G integra is your easiest route.
Try redpepperracing.com for more info.
Old Aug 6, 2005 | 07:57 PM
Spence's Avatar
Default Re: 87 civic what d series motor can i upgrade too? (JDN169)
I dont need anything performance i just want a better motor for daily maybe sohc vtec but just a lower mileage motor
Old Aug 6, 2005 | 08:31 PM
JDN169's Avatar
there arent many motors that will fit without MAJOR modifications, and it all depends on if the Civic is an Si or not. If not, it's carb'd and therefore swapping the fuel system/wiring from an Si is needed before going Fi. If it IS an Si, here are some options:
Replace with what was in it
D16A1 from 1G integra
B16 (needs mounts, costs $$$$$$)
those are the easiest three. If it's carb'd and you dont want to do a lot of work you might as well just rebuild what you've got.
Old Aug 6, 2005 | 09:00 PM
DieMaster's Avatar
Needs to be About 20% Cooler
i have a d16A1 manifold if ur intrested.
Old Aug 7, 2005 | 05:02 PM
Spence's Avatar
bump for a price to rebuild the whole motor?
Old Aug 8, 2005 | 06:47 PM
TunedSiCivic's Avatar
if its already d series then any d series will swap in but no new trannys that are hydrolic only cable theres a way to do it but relocating stuff sucks if i was you i would just spend the money on a cheap like d16a6 and just vtec it you can get the plug and play harness dumb cheap and the power difference for the little S.O.H.C is pretty noticable but thats my opinion though throught i would share.
Serge L
Classic Hondas
Jun 13, 2012 07:37 AM
9db85
Sep 3, 2007 11:21 AM
Jesse's1999honda
Aug 8, 2007 02:28 PM
blckef92ndgen
Dec 5, 2006 09:45 PM
Name Removed
12
Jul 5, 2006 05:50 PM
