91 Civic Konis on 93 Integra????
I was told the OTC koni Yellows for a 91 civic will work on a 93 integra. But after looking on the koni site I see that they are not the same. I already have the Civic shocks and just yesterday picked up the teg to build into a track car. So if there really would be a problem, I wont use them....
I also was under the impression that the ST rear swaybar from the EF civic will fit a DA teggy?
Anyway thanx for any input
The parts for teh cars are definately different, dimensionally and slightly in valving as well with the Integra unit making a bit more force. If you were using a threaded sleeve system, then you can make them fit (the stock spring perch locations are different for sure) but the Civic valving is a bit softer. If you have the Civic units already and plan to use kits, then could be an interim solution. If you were to have them revalved for track use, that would nullify the valving difference. I wouldn't suggest spending much money on Civic Sports for the car as they really are not the preference.
psycho_civic
Jun 8, 2005 12:22 PM
