Help got a 93 4 door lx and dash lights dont work
im driving around during the day, then it gets dark i turn on the head lights and the lights on the dash dont come on
is there a fuse to replace or somthing and where is it at, i still havent recieved my manual yet
thanks so much
thanks so much
your fuse box is under your dash on the right side......it sould have a diagram in it that tells you what ever fuse is for and where it is located, if you don't have one just check them all and replace if any ar bad
also check that you dimmer switch isn't turned all the way down, little spin button on your dash to the left of your steering wheel...
if the dimmer switch is bad or unpluged dash lights wont work either. I know u can connect 2 wires and get them on if the dimmer is bad
VTECtravler
13
Oct 4, 2006 07:51 AM
