Won't Start...
Old Aug 6, 2005 | 07:01 PM
bare's Avatar
Default Won't Start...
Rebuilt Motor.. Ported Etc It's Healthy :-)
Ignition OK , Main Relay OK .. Fuel pump is heard to sart and pressureise system on Key Turn on.. Fuel Filter is New, IAC and Fuel Reulator have been cleaned and seem jes Finme.. Still won't start.
ANY ideas... I'm getting really Pissed at this old worn out car :-)
Old Aug 7, 2005 | 02:19 AM
CRX_Control's Avatar
Default Re: Won't Start... (bare)
Is it cranking ? check the grounds ?
Old Aug 7, 2005 | 06:33 AM
bare's Avatar
Default Re: Won't Start... (CRX_Control)
Thanx.. Grounds are Freshly Cleaned ..all of them.. carefully. Also with every connector in the engine compartment.
TPS? problem
ECU? problem
Errr.. where is ECU hidden?
Old Aug 7, 2005 | 06:57 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bare &raquo;</TD></TR><TR><TD CLASS="quote">Thanx.. Grounds are Freshly Cleaned ..all of them.. carefully. Also with every connector in the engine compartment.
TPS? problem
ECU? problem
Errr.. where is ECU hidden? </TD></TR></TABLE>
Under passenger side carpet. Under a metal plate. Just pull up the carpet a littel, you'll see waht I'm talking about. Although, i don't think this involves your ecu.
Is it cranking?
Old Aug 7, 2005 | 12:46 PM
teknohatchie91's Avatar
Default Re: Won't Start... (88 rex)
check the distributor!
Old Aug 8, 2005 | 11:51 AM
bare's Avatar
Thanx for the responses..
There IS spark ,
there seems to be Fuel (will try the injector spray test tonite)however Ballast resist is within OEM electrical spec as are the injectors. They are getting power, Same for TPS Fuel rail is pressurised
there are NO ecu codes
Have checked and cleaned All grounds.. and Every connector i can find (there are Lots:-)
Timings (rechecked) are as per Honda Workshop Manual.
Damned car was starting running 'Fine' prior to engine work.
This is driving me nuts.
Old Aug 8, 2005 | 12:48 PM
Andy R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">Is it cranking? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">Is it cranking ?</TD></TR></TABLE>
IS IT CRANKING???
if you are 100% sure you have spark and fuel, then if its cranking then your car will start (assuming timing is within range)
Old Aug 8, 2005 | 12:59 PM
88 rex's Avatar
Default Re: Won't Start... (Andy R)
Did you connect the start? Did you install the starter?
Old Aug 8, 2005 | 01:12 PM
ELAMINT5's Avatar
I hate to admit this but I had a simular problem and I had the IVAC and the TPS sensor plugged in backwards. Check that. Also check timing I was off a tooth. A few people have ask you... IS IT CRANKING OVER???
Old Aug 8, 2005 | 02:13 PM
jspecPR26's Avatar
Default Re: Won't Start... (teknohatchie91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknohatchie91 &raquo;</TD></TR><TR><TD CLASS="quote">check the distributor! </TD></TR></TABLE>
yea try that it happen to me
Old Aug 8, 2005 | 03:02 PM
bare's Avatar
Sorry.. YES it cranks overnicely ..and Sparks. the plugs. no issues with starter.. just starting :-)
Will check the IAC and TPS plugs anything is possible.
Other possibles are Crank angle, cylinder sensor inna Dizzy.. But these things throw codes when faulty.. No codes evidentt.
WILL recheck timings yet again.. But everything lined up perfectly at least on the last recheck
Old Aug 8, 2005 | 03:21 PM
ELAMINT5's Avatar
Default Re: (bare)
you will not get any codes until the car starts - at least I didn't when I had to 2 plugs switched - do you have a AFVC? that is how I figured I had the plugs switched, my throttle presure was reading 0. good luck let us know
Old Aug 8, 2005 | 03:36 PM
hondaracing1on12004's Avatar
Default Re: (ELAMINT5)
check for compression
Old Aug 9, 2005 | 07:56 AM
bare's Avatar
Now there's an UGLY thought.. and yes, it had occurred.. just dreading it :-)
Old Aug 9, 2005 | 07:59 AM
Skinflute22's Avatar
check ur timing because if your getting spark and fuel then the timing is really the only thing i could think of...
Old Aug 13, 2005 | 06:23 PM
bare's Avatar
Default Re: (Skinflute22)
FOUND IT :-( Seems that Ierrr Somehow got different Cam posts installed as in they were not the Matched set for that head. Japanese and Canadian Manufacture are NOT the same OR swapable.
Replaced with the correct units and the drag onna Camshaft was reduced/eliminated significantly.. the thing started up instantly.
No substitute fior keeping track of yer bits during Assembly... Always :-)
thanx guys.
silverbur
Feb 5, 2008 01:42 PM
krazydbiker
Apr 4, 2007 08:48 AM
civic89si666
Mar 21, 2006 06:05 PM
NewIntegraKid
Sep 3, 2002 10:09 AM
