How can i tell the width?..
Old Aug 6, 2005 | 03:38 PM
NerveAgent's Avatar
Default How can i tell the width?..
I just got slipstreams and the guy who sold them to me doesn't know the width.
The sticker is pretty much gone so what other way would i find out the width?
15x??
thanks.
Old Aug 7, 2005 | 07:09 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: How can i tell the width?.. (NerveAgent)
Sometimes it's stamped onto the wheel. Otherwise...
The width is measured where the tire bead sits, shown as "wheel width" in the illustration on the Tire Rack website here. So you could just take out a tape measure and measure that dimension on the wheel, if there are no tires already mounted on them.
Note that you DON'T measure the width as the outer dimensions of the wheels. The outer dimensions are usually a good inch or so wider than the specified wheel width.
Old Aug 7, 2005 | 10:42 AM
NerveAgent's Avatar
damn yeah tires are already mounted.
Old Aug 9, 2005 | 12:25 AM
NerveAgent's Avatar
bump
Old Aug 9, 2005 | 05:24 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (NerveAgent)
Try measuring the outer dimensions the best you can (e.g. tape measure going through the wheel spokes) and subtract an inch. It won't necessarily be totally accurate but you have a pretty good chance of hitting it and otherwise it shouldn't be off by more than half an inch.
That's probably the best you can do without removing the tires.
Old Aug 9, 2005 | 06:34 AM
Clay@tirerack's Avatar
Honda-Tech Sponsor
Default Re: (nsxtasy)
It should be stampled on the inside of the spoke area of the wheel. You can usually find the offset dimension here also. Even with the tire on the rim it will still be visible.
Old Aug 9, 2005 | 09:45 PM
NerveAgent's Avatar
on the back of the wheels it says "rota" "1570" "HT" "500K6" and i think thats about it. I measured it and i think its was 8" ( i think i could of been fooling myself) so i guess its 15x7. Anyone with 15x7, 15x6.5 slipstreams know what it says on the back?
NerveAgent's Avatar
oh and it said "40" <--- offset i believe
Old Aug 10, 2005 | 04:16 AM
Honda-Tech Sponsor
The "1570" number means it is 15x7. This would also be confirmed by the 15x8 measurement from the outside of the wheel.
WeakSi
Jun 29, 2010 02:39 PM
Chris F
Mar 28, 2005 06:58 AM
WHiTETYPEs
Jan 27, 2005 04:04 PM
conesmasher
Mar 8, 2003 07:30 AM
