1990 teg cluster into 91 crx
Old Aug 6, 2005 | 03:15 PM
c0nspire's Avatar
Default 1990 teg cluster into 91 crx
please refer to this thread
https://honda-tech.com/zero...26218
Old Aug 6, 2005 | 03:23 PM
Mr_CRX's Avatar
Default Re: 1990 teg cluster into 91 crx (c0nspire)
Bad Link:
Error
You are only authorized to edit your own posts.
» Go Back
Old Aug 6, 2005 | 03:51 PM
c0nspire's Avatar
Default Re: 1990 teg cluster into 91 crx (Mr_CRX)
oops soory
trythis
https://honda-tech.com/zerothread?id=1331428
Old Aug 7, 2005 | 01:30 AM
c0nspire's Avatar
ttt
any help please?
Old Aug 7, 2005 | 01:00 PM
c0nspire's Avatar
i followed the traces on the teg cluster and figured it all out, and i have them all matched up with my crx pinout.
I read somewhere that i do no use the blue plug from the crx cluster. just wanting to confirm this.
Thanks a lot.
Also there is a green plugon the teg cluster behind the tach. It has the same colors are some of the other wires. ie dimmer control, gauge lights, 12v power, and a ground. Do i wire this as those? i just the wires a little short when i pulled it, the ground and the dimmer control are spliced together but the others arent.
Thanks a lot
cmkwood
Mar 31, 2013 09:02 PM
MIGPA26
Jul 7, 2008 01:44 PM
Honduh Tooner
Jul 2, 2005 12:07 PM
El colombiano
Jan 8, 2003 06:20 PM
thaiphob
Oct 16, 2002 12:13 AM
