vss question?
Old Aug 6, 2005 | 03:11 PM
ram0869's Avatar
Default vss question?
i've looked for answers with no success...... i owned a 1996 accord lx with 5sp. the speedo just went out... wanted to know if there is a fuse for the vss.. cause no code was thrown by the ecm,, before the speedo went out, i got the smell of plastic burning not a strong smell but able to smell it i thought it was the traffic around me but then after a while noticed my speedo was gone any suggestion .... thank you
Old Aug 6, 2005 | 03:13 PM
YeuEmMaiMai's Avatar
Default Re: vss question? (ram0869)
since you smelled burning plastic I would guess that your cluster is the problem. I would check the cluster first.
Old Aug 6, 2005 | 03:15 PM
ram0869's Avatar
forgot to mention that i did remove the cluster and check the gauge no burning smell in any place near the cluster or engine compartment?
Old Aug 6, 2005 | 09:00 PM
raceACCORDingly's Avatar
try a new vss
Old Aug 6, 2005 | 09:10 PM
i20ar's Avatar
i think its your cluster... the plastic smell was probably the speedo circut burning... if you can try getting a new speedo ... unless the vss is located in your cabin .. i dont think you would be able to smell it.. if you go to those small junk yards/ wrecking yard.. where the guys have most of the parks already on shelves.. maybe you can ask them if you can plug one of the used speedos in and see if it works.. im pretty sure they let you take one around the bluck if you left your id with them or sumthing
Old Aug 8, 2005 | 12:32 PM
Rubixcu7's Avatar
i had the same problem, speedo went out but no code was thrown. is there a fuse for the speedo?
Old Sep 5, 2009 | 09:11 PM
AJ_ashu9uf's Avatar
if speedo is out, but tacho is still running good, is it still the VSS?
mikej94civex
May 25, 2010 05:09 PM
JDMJUNKIEMONKIE
11
Feb 2, 2010 09:41 PM
jerry_ort007
Feb 17, 2009 07:00 AM
itr1235
Jun 2, 2004 08:39 PM
mc
Apr 19, 2004 07:58 PM
