Resistor Trick On O2 sensor for Cat Converter in civic
Old Aug 6, 2005 | 02:46 PM
b18c1EKcivic's Avatar
Default Resistor Trick On O2 sensor for Cat Converter in civic
I was wundering which resistor I need to use to trick the ecu in thinking everything is ok and stop throwing a code from my 2nd O2 sence i have a high flow cat?
Old Aug 6, 2005 | 04:01 PM
Magick211's Avatar
Default Re: Resistor Trick On O2 sensor for Cat Converter in civic (b18c1EKcivic)
Bump, I would like to know this also.
Old Aug 6, 2005 | 04:12 PM
b18ccivics's Avatar
there is no resistor trick for that, I wish it was that easy. you should be able to weld and 02 bung on the test pipe and only have the tip of the o2 sensor barely in the pipe. you will probably have to take 2 bungs and weld them together to get the sensor backed out of the pipe enough.
93_DailyDriver
Jun 5, 2011 11:10 AM
b18cisbetter
Jun 15, 2008 11:05 PM
stepasha
Feb 9, 2008 12:39 PM
rebuiltSI
Jun 29, 2007 05:56 AM
Mike95lude
Jan 16, 2002 09:19 AM
