s2s3 too much with no headwork?
Old Aug 6, 2005 | 09:06 AM
xDicktonesx's Avatar
Default s2s3 too much with no headwork?
would a skunk2 stage 3 be too radical with no headwork and an 11.8:1 CR?
Old Aug 6, 2005 | 09:08 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: s2s3 too much with no headwork? (CRXofPain)
depends on the motor, what is your setup.
Old Aug 6, 2005 | 10:11 AM
Default Re: s2s3 too much with no headwork? (PURPLETERROR)
b16 82mm bore
11.8:1 comp
smsp header
aebs manifold
head will be milled 0.035 with stock HG
thats all that will effect the cam selection. my other alternatives are BC4 or jun 3 or 4 from what ive been looking at. ive already got a beefy valvetrain brand new in a shoebox. so i cant justify the 9-something for the rockets plus the valvetrain. only looking to make power to about 9300 or so. want something similiar to roger foo's old set-up. only difference being the enlarged bore. thats where im looking to make more power.
i just dont want to have to take my head to portflow or alaniz and throwdown 1400 for a headjob and a 2 week turn around if i can get away with cleaning up the ports myself. mostly just a little polishing of the floors
Modified by CRXofPain at 11:24 AM 8/6/2005
Old Aug 6, 2005 | 10:26 AM
injectors are rc 310
im still working with the ecu. right now its a chipped pw0 with a safc2.
Old Aug 6, 2005 | 10:33 AM
skunk2 pro1's stage 3's are to big for that motor.
Old Aug 6, 2005 | 10:40 AM
xEnderx's Avatar
Is tha tyour compression ratio before or after the head milling?
Old Aug 6, 2005 | 11:01 AM
Default Re: s2s3 too much with no headwork? (xEnderx)
thats the final CR after the mil is done. pistons domed 5cc
stage3 too large? i thought the pro series was larger than all that came before it and skunk2 stage 3 came before the pro series so wouldnt that make the stage 3 more mild that the pro 1s? maybe im just effing lost. ill probably run what steve the omni dude ran in his which is dynamic stage a for those of you not in the know
Old Aug 6, 2005 | 11:04 AM
xEnderx's Avatar
The cams would likely work pretty well, but I'd say you could get optimal power with somethign a bit smaller. Just my opinion mind you.
Old Aug 6, 2005 | 11:25 AM
jun 3 maybe? toda c?
im not looking for a dyno queen or bragging rights i just know that 125 ft lbs and 200whp is possible from 1595 cc and i want something i can run the **** out of at buttonwillow and vegas. 200hp is more interesting when the front of the block says b16a 5768201
thanks for the help
Old Aug 6, 2005 | 11:36 AM
xEnderx's Avatar
Not sure.....I'd do searches and compare the specs on the 3 cam sets. If I recall correctly the Jun 3's did very well on a 16A head with SMSP header. Try doing an search for it, but thats the direction I would start looking in.
Old Aug 6, 2005 | 12:43 PM
Rollo Lawson's Avatar
Roger Foo made 193whp, or so. and the main reason he made it was the headwork. i believe Omni did the work. oh yeah, Foo only had s2s1's, and, a sick f.d. to get that 16 to sing. g/l with the project
Old Aug 6, 2005 | 08:24 PM
Default Re: (B16C1)
thanks. as soon as i heard the power number i knew it had to be headwork. time to start talking to portflow. he did omnis 200hp b16 head. apparently its "all in the angles" sounds like a sick valve job.
Old Aug 6, 2005 | 08:29 PM
GOLDBERG's Avatar
Default Re: (CRXofPain)
stage 3's would be too big for a 1.6L in my opinion... omniman used m22's too reach the 200whp mark i believe
Old Aug 7, 2005 | 03:53 AM
EG92's Avatar
for the money you cant beat the s2s2's for your setup
Old Aug 7, 2005 | 09:06 AM
Default Re: s2s3 too much with no headwork? (EG92)
he didnt usae rockets he used dynamic stage a. waitll the dvd comes out.
i just want something bigger than a skunk2 stage2. im goign to go forth with the headwork. and i think 11.8:1 is enuff comp to run something larger.
im not dismissing info that i dont want to hear as incorrect or anything i just think theres a happier medium between s2s2 and say a s2 pro stage 3 or bc5.
Old Aug 7, 2005 | 09:13 AM
UncleD's Avatar
Steve was using the Dynamic Autosports cams, but he switched them out for the M22's to get him past 200. I would be really concerned about valve to piston clearence with a S2S3 since you have milled the head. 12.8 is a TON of lift, I would opt for the M22 with your motor set up..they would absolutely rip. A Jun 3, S2S2, or S2 Pro 1 would work well also. M22's LOVE B16's
Old Aug 7, 2005 | 09:15 AM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXofPain &raquo;</TD></TR><TR><TD CLASS="quote">he didnt usae rockets he used dynamic stage a. waitll the dvd comes out.
im not dismissing info that i dont want to hear as incorrect or anything i just think theres a happier medium between s2s2 and say a s2 pro stage 3 or bc5.</TD></TR></TABLE>
he did used dynmics..but then changed em out and gained with the m22's..thats what he told me anyway
Old Aug 7, 2005 | 09:18 AM
GOLDBERG's Avatar
and i dont think a pro stage 3 has been released yet..has it even been made?
Old Aug 7, 2005 | 09:31 AM
Default Re: s2s3 too much with no headwork? (GOLDBERG)
i meant pro 2. sorry. typo. where can i get m22 without gettign the valvetrain with it? or is that a no-go. also...is the m22 an entirely new concept or is ther something very very close if not identical out there? i heard the june 3 and s2s2 are identical. im not trying to take away from the rocket guys at all. just kinda would liek to know.
Old Aug 7, 2005 | 09:48 AM
GOLDBERG's Avatar
try searchin around.. boosted_hybrid had some for sale ...might be others out there with em fs
Old Aug 7, 2005 | 11:13 AM
xEnderx's Avatar
Default Re: s2s3 too much with no headwork? (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">M22's LOVE B16's </TD></TR></TABLE>
Thought you said it was overcammed?
Old Aug 7, 2005 | 11:15 AM
DonF's Avatar
The Pro3+ is available.
Old Aug 7, 2005 | 12:18 PM
UncleD's Avatar
Mine is overcammed right now, but only because I am TRYING to run the stock ecu, injectors, timing and header right now
Old Aug 7, 2005 | 12:19 PM
xEnderx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Mine is overcammed right now, but only because I am TRYING to run the stock ecu, injectors, timing and header right now </TD></TR></TABLE>
Ah.....gotcha.
Old Aug 7, 2005 | 12:21 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXofPain &raquo;</TD></TR><TR><TD CLASS="quote">is the m22 an entirely new concept or is ther something very very close if not identical out there?</TD></TR></TABLE>
The M22's and S2 Pro 1's, depending on what motor, build very similar horsepower. I like the duration of the M22's for a B16, they give it an awesome top end pull. The S2 Pro 3's are only available to "certain" people. I read somewhere that Dave isn't going to sell them to just anyone, like a full blown race cam only.
