Now a certified orbital welder! My first weld.
Old Aug 5, 2005 | 10:48 PM
Br1anPham's Avatar
Default Now a certified orbital welder! My first weld.
Tell me what you think.
100%argon gas 316stainless steel, 1.5 OD tube.
Heres a crappy picture of the ID
Modified by Br1anPham at 12:11 AM 8/6/2005
Old Aug 5, 2005 | 11:14 PM
own6volvos's Avatar
unf unf unf
Old Aug 5, 2005 | 11:27 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: Now a certified orbital welder! My first weld. (Br1anPham)
What are you plans for the futurs? Build headers? Turbo manis? DPs? ...etc.
Old Aug 6, 2005 | 12:35 AM
Nutzurchin's Avatar
Default Re: Now a certified orbital welder! My first weld. (NightRider-gsR)
Good work brian
Old Aug 6, 2005 | 12:41 AM
Br1anPham's Avatar
Default Re: Now a certified orbital welder! My first weld. (Nutzurchin)
Future is far away.
I've thought about after finishing school and go on from there.
I have not really thought too much about making stuff for our cars, business-wise anyway. Mainly just trying to maybe find a job or make some money welding and see if its my thing.
But if your looking for manifolds or downpipes for whatever, Nutzurchin is an awesome welder thats already in the field, making some mean manifolds.
Old Aug 6, 2005 | 01:42 AM
DATZ WEAKSAUCE's Avatar
supremacy lab on the come up huh brian
Old Aug 6, 2005 | 03:43 AM
Flashmn's Avatar
Default Re: Now a certified orbital welder! My first weld. (DATZ WEAKSAUCE)
Those are some really sweet welds.
Old Aug 6, 2005 | 07:00 AM
mamaboy's Avatar
are you a robot?
Old Aug 6, 2005 | 07:09 AM
LSVtechnologytur...'s Avatar
Default Re: Now a certified orbital welder! My first weld. (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">are you a robot?</TD></TR></TABLE>
Old Aug 6, 2005 | 07:53 AM
DamWutaDayM3's Avatar
That is nice.... :Drooling:
Old Aug 6, 2005 | 08:07 AM
damnraz's Avatar
Default Re: (DamWutaDayM3)
I'm a certified boeing orbital welder using 2" OD titanium at .028 hell I don't know, I just pressed a button and made a cool fusion weld, ****'s complicating I tell you.. jk.. aha
Old Aug 6, 2005 | 10:46 AM
Br1anPham's Avatar
Default Re: (damnraz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damnraz &raquo;</TD></TR><TR><TD CLASS="quote">I'm a certified boeing orbital welder using 2" OD titanium at .028 hell I don't know, I just pressed a button and made a cool fusion weld, ****'s complicating I tell you.. jk.. aha</TD></TR></TABLE>
Titanium welds so nice..
But yeah its crumb pie once you got the weld schedule and tweaks all setup.
Fab-Works's Avatar
sweet! good **** man!
Old Aug 6, 2005 | 12:39 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default Re: Now a certified orbital welder! My first weld. (Fab-Works)
if you honestly want to know what I think....(after having been doing shitty MIG welds for 3 hrs)
[thinking]
holy shoit...thats magic, right? HTF did he do that?
[/thinking]
Old Aug 6, 2005 | 04:42 PM
Engloid's Avatar
OG Fabricator
Default Re: Now a certified orbital welder! My first weld. (tharptroy)
What machine?
Liburdi?
Old Aug 6, 2005 | 10:20 PM
Br1anPham's Avatar
Default Re: Now a certified orbital welder! My first weld. (Engloid)
AMI 207HP with a 9-2500 head.
Old Aug 6, 2005 | 11:14 PM
Seanith's Avatar
Those are some clean fuggin welds
Old Aug 7, 2005 | 12:30 AM
blackwagon's Avatar
Default Re: Now a certified orbital welder! My first weld. (Seanith)
WTHs a orbital welder? Those both fusion welds, just diff heats? Do you use any filler in orbital welding? I've never heard of it...
Old Aug 7, 2005 | 04:22 AM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1anPham &raquo;</TD></TR><TR><TD CLASS="quote">AMI 207HP with a 9-2500 head.</TD></TR></TABLE>
The AMI machine I have used will add filler metal. Did that head have the capability and you didn't use it?
Another thing that works well: use 95% Argon/ 5% Hydrogen gas on the outside, but still purge with Argon. This will let you get the same penetration and width of root, but have a narrower bead outside. In other words, with it having a wider root, it greatly decreases the chance of the weld missing the seam on the inside.
Old Aug 7, 2005 | 08:19 AM
Engloid's Avatar
OG Fabricator
Just some FYI....
Some welding specifications, such as BPE (BioProcessing Equipment), will require that you run a test piece at the beginning of each shift and if you stop welding for any period longer than 30 minutes during the day and when there's any change in size of tubing. In other words, depending on the code you're welding to, you may have to run several test coupons a day.
I won't say I agree with the 30 minute thing, but it makes sense to do a test run for each shift and tube size...to make sure you don't mess up a good part.
Old Aug 7, 2005 | 12:36 PM
Br1anPham's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">Just some FYI....
I won't say I agree with the 30 minute thing, but it makes sense to do a test run for each shift and tube size...to make sure you don't mess up a good part.</TD></TR></TABLE>
Right, Thanks for the tips.
95/5 cost a bundle, but when I do get the chance, I'll def try 95/5 outside and 100 purge.
Do you remember which AMI machine you use? I dont recall beging taught that the 8 or 9-series head will add filler metal. Though I know certain machines do, like some machines they use to weld 2'' ID pipes and some others.
Old Aug 7, 2005 | 01:38 PM
Engloid's Avatar
OG Fabricator
I don't remember which weld head it was that I used. It worked great, and would do everything....except for what the company had bought it to do. they wanted to be able to weld sch 40, 254SMO material with one pass....and no bevel. I told them after a few days of experimenting that it wasn't going to do it. After about 3 weeks, they pulled me off the machine and set it in a corner. Now, it's over a year later and the machine is still sitting. $70k spent, and it's never even seen production welding.
Old Aug 7, 2005 | 04:59 PM
CRXDrew's Avatar
This had me laughing for a bit.
Old Aug 8, 2005 | 10:54 AM
Br1anPham's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">I don't remember which weld head it was that I used. It worked great, and would do everything....except for what the company had bought it to do. they wanted to be able to weld sch 40, 254SMO material with one pass....and no bevel. I told them after a few days of experimenting that it wasn't going to do it. After about 3 weeks, they pulled me off the machine and set it in a corner. Now, it's over a year later and the machine is still sitting. $70k spent, and it's never even seen production welding.</TD></TR></TABLE>
Old Aug 9, 2005 | 08:40 PM
parasonic's Avatar
Default Re: (own6volvos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by own6volvos &raquo;</TD></TR><TR><TD CLASS="quote">unf unf unf</TD></TR></TABLE>Exactly. I'd hit that.
