d16y8 has LOUD pinging noise at 1/4 throttle and up.
Old Aug 5, 2005 | 07:49 PM
mike93eh
Guest
Posts: n/a
Default d16y8 has LOUD pinging noise at 1/4 throttle and up.
okay my friend has a bone stock 97 civic ex. nothing has been touched on the engine for a long time and about 2 weeks ago out of the blue it started making a REAL LOUD pinging noise. it doesnt do it at idle. it does it the loudest at about 1/4 throttle. you can hear him coming a mile away its so loud. real loud in the car. its definetly coming from the engine. but the funny thing is if he is holding the throttle 1/4 down and i pull the #1 plug wire off, the pinging goes completely away. same thing if i unplug the fuel injector for the #1 cylinder.
i have check/performed the following.
-checked ignition and cam timing
-adjusted valves
-checked fuel injectors, all working
-replaced plugs, wires, cap
-checked for exhaust leak, maybe vacuum leak??
i dont know if its bad gas or not because he has already let it get empty and refilled at different gas stations and its still doing it. but its definetely has something to do with the #1 cylinder because it goes away when we pull that plug. the higher the rpms, the faster it will ping.
on a side note though: the car drives excellent, no problems at all besides that really loud pinging. im sooooo stumpped, i have never been this stumped before. i hope HT can pull through, please help me
Old Aug 5, 2005 | 08:07 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: d16y8 has LOUD pinging noise at 1/4 throttle and up. (mike93eh)
Are you sure it's a ping? As in a higher-pitched ping or ticking noise? Or is it more like a knocking sound?
Old Aug 5, 2005 | 08:37 PM
mike93eh
Guest
Posts: n/a
more of a higher pitched sound.
Old Aug 6, 2005 | 06:47 AM
mike93eh
Guest
Posts: n/a
i really need some help guys..
Old Aug 6, 2005 | 04:27 PM
mike93eh
Guest
Posts: n/a
Old Aug 6, 2005 | 06:33 PM
cisurfer1's Avatar
Default Re: (mike93eh)
Use the good gas, my friend said it was spark knock? or something like that. My old z6 used to do it when i ran cheap gas.
ninjacowtipper
Sep 25, 2012 09:50 PM
ih8danoles
13
Aug 29, 2004 08:09 AM
neumonik
Aug 25, 2004 06:37 PM
HX_Guy
Feb 13, 2002 07:42 AM
