1.6 VTI upgrade
Old Aug 5, 2005 | 07:37 PM
delectric's Avatar
Default 1.6 VTI upgrade
Now is time to make some changes in my B16A2 motor.
I was thinking in:
EvoTT GReddy exhaust system
Cams gears (What do you recommend?)
Supertech springs and retainers
P28 & Hondata
Intake Manifold & Throttle Bodies (What can i use?)
440cc injectors
Open to suggestions.........
How many hp can be spected from these modifications
Sorry for my english and thanks anyway.
Old Aug 5, 2005 | 08:22 PM
xEnderx's Avatar
Default Re: 1.6 VTI upgrade (delectric)
Unless you add some cams I'd hold off on the cam sprockets....also look into Neptune of Chrome....might suit your needs better than Hondata. I woudl FOR SURE not invest in the springs and keepers unless you go with better cams. Also those injectors are going to be an overkill wihtout (yet again) bigger cams, a displacement increase, or some kind of boost. Intake manifold....Blox, AEBS, or OE type R. Same advice on TB.
Old Aug 5, 2005 | 08:38 PM
onepoint6i's Avatar
Default Re: 1.6 VTI upgrade (xEnderx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">Unless you add some cams I'd hold off on the cam sprockets....also look into Neptune of Chrome....might suit your needs better than Hondata. I woudl FOR SURE not invest in the springs and keepers unless you go with better cams. Also those injectors are going to be an overkill wihtout (yet again) bigger cams, a displacement increase, or some kind of boost. Intake manifold....Blox, AEBS, or OE type R. Same advice on TB.</TD></TR></TABLE>
i agree.
stick with stock injectors and get yourself a fuel pressure riser instead
Modified by 1.6i at 10:20 PM 8/5/2005
Old Aug 6, 2005 | 10:27 AM
delectric's Avatar
Many thanks xEnderx and 1.6i for yours advise. What do you think about that?
ITR Cams and what gears?
AEM Ecu will be better or another brand?
Fuel pressure riser or a complete fuel system? (posible turbo-kit in the future)
Thanks for all
Old Aug 6, 2005 | 10:35 AM
xEnderx's Avatar
R cams are good.....I'd reccomend those to anyone. Unless you SERIOUSLY plan on having yoru car dyno tuned then don't go with teh support mods like cam sprockets and/or fuel system stuff. Its a good way to end up runnign too rich becuase the temptation to dump more fuel is too much to resist. Buy some good bolt ons....RS*R exhaust, RMF (or SMP) header, maybe a type R intake manifold.....thats the kind of stuff you should be looking at to start out with.
6strngs
Feb 2, 2014 04:13 PM
civics4lyfe
Jun 17, 2013 09:26 PM
DelSol_F20B
12
Aug 13, 2009 08:20 AM
b18c-1
24
Oct 11, 2006 02:00 PM
EK9 BEEZLER
Mar 24, 2005 08:05 PM
