weak, short first gear?
stock 95 si lude. when i start moving from a stop it does pull but it dosent move me back in my seat like 2nd/3rd etc. and i redline @ around 25mph in first. is this normal? and whats does a transmition slipping feel like. IM new to manual tranys. 95
It sounds like the clutch might be just starting to slip. It sounds like his clutch is slipping through first gear and then it catches for the rest of the gears.
Try SLOWLY accelerating to redline in 1st. See if your redline speed is higher. It should be about 40mph (not sure of the exact speed)
Try what I said. If you redline at a higher speed, your clutch is slipping. Also try flooring it in 5th at around 1-2krpm. See if your revs shoot up really fast.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacklude05 »</TD></TR><TR><TD CLASS="quote">ill try it tomorrow in the morning. thx for help, if it is slipping, do i need to get a new clutch? how much would it cost?
If your car is stock, I would reccomend a stock replacement clutch. They're really cheap. That's what I plan on getting for my car. Check the sponsors section.
</TD></TR></TABLE>If your car is stock, I would reccomend a stock replacement clutch. They're really cheap. That's what I plan on getting for my car. Check the sponsors section.
okay i checked the 5th gear, (shifted to 5th, and at ~1k rpm i floored it, and the rpm's didnt fly up, slow accel) so i red line 1st at about 30mph.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil »</TD></TR><TR><TD CLASS="quote">1st gear at 7500rpm should be 36mph.</TD></TR></TABLE>
Whoa there! He has an Si, not a VTEC. Redline is 6400 RPM. In my experience, you might get past 30 mph at redline in 1st with the Si gearing.
First gear should be the jerkiest. If you're not feeling as much go from 4k rpm in 1st as in 3rd, it would make sense that the clutch is starting to slip just in 1st because that gear is torquey enough to make it slip when you punch it or when you start, but the others are not.
Try this: With the e-brake pulled, rev it about halfway up and slowly pull up the clutch. If the car doesn't start to stall, your clutch is probably slipping.
Dan
Dan
vtecguy
Oct 8, 2001 12:45 PM
