suspension making squeak ass noise
Old Aug 5, 2005 | 06:49 PM
djsire's Avatar
Default suspension making squeak *** noise
what do i need to buy/ replace? shocks? struts? springs? when i hit a bump there is no comfort. you feel everything. everything is original i think. please help!!!
crx si 89
Modified by djsire at 4:03 AM 8/6/2005
Old Aug 5, 2005 | 07:03 PM
CRX_Control's Avatar
Default Re: suspension making squeak *** noise (djsire)
you need to buy new shock for the side that is blown. ( most likely blown)
Old Aug 5, 2005 | 07:39 PM
EFbomb's Avatar
squeaking is usually ball joints/tie rod end
replace them asap, if one snaps, your wheel will fall out sideways or under and possibly cause some body damage as well as trash the entire suspension and axle and brake lines upthere.
speaking from expierence
Old Aug 6, 2005 | 05:33 PM
djsire's Avatar
Default Re: (EFbomb)
it happens all the time not only when im turning
hispanic panic
Sep 30, 2011 01:13 PM
Flash_07
Sep 11, 2005 08:12 PM
raceboy71
Jan 27, 2005 08:48 PM
95AccordDX
Mar 23, 2004 04:45 PM
nugget8000
Jan 22, 2002 01:13 PM
