NEED HELP!!! zc pass smog Q"s?
Old Aug 5, 2005 | 05:17 PM
luvef's Avatar
Default NEED HELP!!! zc pass smog Q"s?
i have a 89crxsi im puting a zc (dohc) into it. I know that cats can help but what i was wondering if i were to just use the stock si ecu for the smog if that can help improve my chances or even an ecu out of an 88 teg might be better. if someone has done this please i need help asap motor will be hear soon
Old Aug 5, 2005 | 07:38 PM
Voodooboy520's Avatar
the PM6 is very well matched to the DOHC ZC, the teg ECU is better, PM7 is best
Old Aug 5, 2005 | 08:03 PM
so-cal-ef's Avatar
Default Re: NEED HELP!!! zc pass smog Q"s? (luvef)
that dohc will pass smog just use si intake manifold that motor can be refed ive done it
Old Aug 5, 2005 | 08:05 PM
luvef's Avatar
Default Re: NEED HELP!!! zc pass smog Q"s? (so-cal-ef)
thanks that helps me alot
Old Aug 5, 2005 | 09:22 PM
N_A_is_best's Avatar
fuel pressure regulator and turn it down before getting there
Old Aug 5, 2005 | 11:39 PM
luvef's Avatar
Default Re: NEED HELP!!! zc pass smog Q"s? (N_A_is_best)
how do you ajust the regulator? can i just pinch a return line?
ZCHF
Feb 4, 2005 12:09 PM
drastikmeasurez
20
Feb 3, 2004 08:17 PM
Rostr02
13
Oct 9, 2003 08:44 AM
chief_rucka
Aug 19, 2002 07:40 AM
