NNNNEEEEEEEEEEDDDD some HELPP
Old Aug 5, 2005 | 04:46 PM
civic efb16's Avatar
Default NNNNEEEEEEEEEEDDDD some HELPP
i have a 90 civic hatchback with a b16 i need help wen i turn on my headlights the hazard lights stay on not blinkin but just stays on and wen i also press the brakes also wen my car starts it idles then dies and my fuel level goes past E wen i have gas in my car and i replaced the fuel filter ppl are sayin its tha fuel pump but i dont how its affectin the lights turnin on like that
Old Aug 5, 2005 | 05:04 PM
.Ash's Avatar
Old Aug 5, 2005 | 05:08 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
the wires are crossed somewhere.....just dont know where....who did the swap?
Old Aug 5, 2005 | 11:42 PM
DADADAAAMN's Avatar
Default Re: NNNNEEEEEEEEEEDDDD some HELPP (civic efb16)
HOLLY ****** RUN-ON BATMAN!
Old Aug 5, 2005 | 11:50 PM
.cingham's Avatar
best bet is to go over the wiring...who did the swap is a big factor as well.
no one is going to be able to just say its the green wire next to the fire wall.
Bad wiring is basically your answer, and anyone saying a fuel pump is your problem needs to be kicked in the nuts and told that APC is'nt a performance part.
/thread
Old Aug 6, 2005 | 03:02 AM
ALLMOTORCRX20's Avatar
my brother had the same problem with the lights and the car turning off. It was a loose ground wire. In the back of my brother's CRX, there are like 5 black wires that all meet together and connect to a bolt. One of those wires goes from the tailights to that ground. The bolt turned out to be loose. You might wanna check that wire. Also, check all your grounds.
cholder919
Feb 4, 2013 07:14 AM
anthony01
Dec 15, 2012 06:15 PM
streetsold6teeny8
Jul 25, 2011 01:15 PM
Yellowone
12
Apr 25, 2008 12:51 PM
dirty_d_cx
Oct 15, 2003 08:29 PM
