Suspension & Brakes Theory, alignment, spring rates....
TEIN S.Tech's
Old Aug 5, 2005 | 04:26 PM
barely4dr's Avatar
Default TEIN S.Tech's
I have a 1990 civic Lx. I'm looking into lowering it with tein s.tech lowering springs but i don't know whether or not these springs will blow out my shocks or not. I would also like to know whether I will need a camber kit b/c of the lowering and if alignment will be needed. I DO plan on doing a full suspension upgrade with performance shocks/lowering springs but right now, money only permits the purchase of the springs and I really want/need to be lower. ANY and ALL help will be greatly appreciated. Thanx in advance.
*For the visual, look at my ride:
https://honda-tech.com/zerothread?id=1326303
Old Aug 7, 2005 | 03:10 AM
ElementMotor's Avatar
Default Re: TEIN S.Tech's (barely4dr)
The S Tech's are not that much of a drop. Stock struts will be fine. I wouldn't worry about camber with those springs, they are a pretty mild drop. I'd only get a camber kit if you go lower than 2-2.5".
Old Aug 7, 2005 | 03:24 AM
barely4dr's Avatar
Default Re: TEIN S.Tech's (GSRchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRchris &raquo;</TD></TR><TR><TD CLASS="quote">The S Tech's are not that much of a drop. Stock struts will be fine. I wouldn't worry about camber with those springs, they are a pretty mild drop. I'd only get a camber kit if you go lower than 2-2.5".</TD></TR></TABLE>
Yeah, I just want my car to have a little better stance, will the S.Tech's give me that? Also, how will the ride be with them? I'm not looking for a "luxury" status ride, but I want something that will be comfortable enough to be able to cruise the highways/freeways without jumping and bouncing out of my seat. However, I would also like to [possibly] be able to take a few tight turns successfully [ya know ?]. Will the S.Tech's live up to those expectations?.......Any feedback, plz.
Old Aug 7, 2005 | 01:20 PM
The S tech's for the EF are only a 1.6"F and 1.4"R drop.....so its not going to ride harsh at all, you will barely notice the difference. As far as cornering ability goes, it will improve a little bit, but you are going to still have a lot of body roll being that the drop isn't that much and the springs are really soft.
Old Aug 8, 2005 | 02:48 AM
barely4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRchris &raquo;</TD></TR><TR><TD CLASS="quote">The S tech's for the EF are only a 1.6"F and 1.4"R drop.....so its not going to ride harsh at all, you will barely notice the difference. As far as cornering ability goes, it will improve a little bit, but you are going to still have a lot of body roll being that the drop isn't that much and the springs are really soft.</TD></TR></TABLE>
That's cool b/c I plan on going with some KYB or Koni [or whatever is good quality/affordable] shocks pretty soon but I've got to get this thing a little closer to the ground. Thanx again man, you've been a bigger help than you know.
Old Aug 8, 2005 | 01:54 PM
Earthworm Jim's Avatar
If you plan on circuit racing your car they would be nice. I don't see that happening, get some Tein springs, gas shocks from Kragen, and you're good
bluelude92si
Suspension & Brakes
Dec 9, 2007 08:08 AM
Mr.VoRt3X
Jun 10, 2007 02:43 PM
dELfONiK
Jul 26, 2005 04:22 PM
spooniq
Honda S2000
Sep 7, 2004 01:04 PM
clutch33
Mar 9, 2004 06:15 AM
