Suspension & Brakes Theory, alignment, spring rates....
Front too low on koni/gc combo
Old Aug 5, 2005 | 02:20 PM
sudds's Avatar
Default Front too low on koni/gc combo
I just put these bad boys on and the front of the car is too low. I try to adjust it but it seems like the shock is full extended, and the coil over adjustment ring will not adjust up anymore. They are the sp3's, and I am using the gc top hats also. Do I need to compress the spring before I put them on? I'm confused please help.
dave
Old Aug 5, 2005 | 02:48 PM
Marauder's Avatar
Default Re: Front too low on koni/gc combo (sudds)
There is a sir clip that adjusts the spring perch of the shock. Make sure its not on the bottom:
Also, make sure you installed the brake cable bracket.
Old Aug 5, 2005 | 02:53 PM
sudds's Avatar
Default Re: Front too low on koni/gc combo (Marauder)
The circlip is in the stock location, and I have no brake brackets. The tokico's were welded on, but the space where the brake bracket should go is still there.
Old Aug 5, 2005 | 04:17 PM
Tyson's Avatar
its the GC top hats that are causing you to not have enough room to raise it. if you want to go higher, i would suggest you remove the top hat, since you probably dont need it. GC top hats are used when you want to ride low. you apprently dont care to, which is just as fine.
Old Aug 5, 2005 | 07:05 PM
sudds's Avatar
Default Re: Front too low on koni/gc combo (Tyson)
Thank you sir. I will give it a shot.
Old Aug 5, 2005 | 07:21 PM
CRX Lee's Avatar
As mentioned above, the GC upper mounts will require that you preload the spring more when it is off the car. You can remove the top mount of you can use a spring compressor and run the perch up higher. This is one of the overlooked side effects of using these style upper mounts, you need more preloading of the spring when the unit is off the car.
eg6noise
Suspension & Brakes
Aug 9, 2018 06:31 AM
fast95se
Nov 2, 2006 06:38 AM
fireant
May 4, 2005 06:47 AM
tolnep
Jul 11, 2004 08:25 AM
CRXTSEE
Apr 10, 2003 07:19 AM
