need help..... lower rear tie bar
i tried searching but couldnt find exactly what i need to find.
i know how to put it on, although when i bought it. It just came with the bar, no spacers/washers and no new bolts.
my question is can i use home depot washers for spacers, and do i need to get longer lca bolts??
thanks fo any help
-sean
thanks fo any help
-sean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUNNER666 »</TD></TR><TR><TD CLASS="quote">bump i need some input
Yes you can use regular washers, (shims) from lowe's/ home depot etc. Just make sure to take your bolt that holds the lca in place and place the washers on it to ensure that it fits.
</TD></TR></TABLE>Yes you can use regular washers, (shims) from lowe's/ home depot etc. Just make sure to take your bolt that holds the lca in place and place the washers on it to ensure that it fits.
Yes you can use any washer/shim that will fit your bolts from your lca's
</TD></TR></TABLE>Yes you can use any washer/shim that will fit your bolts from your lca's
okay but what about the lca bolt, it seems to short..... where would i get a longer one??? and i know not from home depot!! from honda maybe???
CRX EF 88
12
Feb 20, 2008 05:54 AM
whitef
Nov 17, 2007 12:52 AM
SD_EM1
Jun 10, 2004 11:28 PM
