Running rich? reving issue? Help?
Old Aug 5, 2005 | 01:37 PM
lavo81's Avatar
Default Running rich? reving issue? Help?
i went to a mechanic and he said i was running rich nothing but stock d16z6 swaped in and using a p06 ecu someone told me that was for d15b motor would this cause me to run rich or lean?
more info (today: aug 5th) :: this might not be why its running rich though...
a vacum line on the zc engine (sohc vtec (JDM)) there is no nossle to attach the vacum line on the back of the Intake Manifold so i was told to just plug it , and i did. the car sometimes wont stay a constant speed it either you gain speed or you slow down and when accelerating in first if u dont go to higher rpms fast enough it will stop and go stop and go...
if u are at a stop and push the gas down about 1/2 an inch and hold it there the engine goes vrroooom... nothing.... vroooommm.... nothing vroooomm. nothing but if u hold it in the higher rpms it goes vrooooooooooommmm as long as u hold it down and dont go in the lower rpms. i dont have a rpm gage. this gets annoying when driving please help fix both.!!!...!
Old Aug 5, 2005 | 03:11 PM
lavo81's Avatar
Default Re: Running rich? reving issue? Help? (lavo81)
bump
Old Aug 6, 2005 | 05:21 AM
lavo81's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lavo81 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Old Aug 6, 2005 | 12:04 PM
lavo81's Avatar
come on someone please help me ive got nothing
Old Aug 7, 2005 | 01:12 PM
lavo81's Avatar
BlackCivicEX
Nov 8, 2011 05:03 PM
slowem1si
Apr 4, 2006 03:09 PM
