Window washjer jets - Tucking the lines under hood
Old Aug 5, 2005 | 11:34 AM
Ax3l's Avatar
Default Window washjer jets - Tucking the lines under hood
Any tips on how to tuck the ugly plastic/rubber lines that go from the washer fluid tank to the jets that squirt the stuff on the windshield? Where could i run the lines so that it looks a bit better... They are so ugly when i open the hood...
97 Civic by the way.
Old Aug 5, 2005 | 12:02 PM
gftgrill's Avatar
paint them the color of the car so they're camoflauged(sp)
Old Aug 6, 2005 | 08:04 AM
Ax3l's Avatar
Default Re: (gftgrill)
The lines will still be hanging down under the hood...
how to tuck them?
Old Aug 11, 2005 | 10:53 AM
gftgrill's Avatar
drill some holes in the metal subframe of the hood and run them through there.
or you could get the type of spray nozzles that hook on your wiper arms. then you have to re-route the tubes to them and you can remove all of the tube under your hood. but then you're left with two nozzles in your hood that don't do anything.
Old Aug 11, 2005 | 12:14 PM
-Gambit-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill &raquo;</TD></TR><TR><TD CLASS="quote">drill some holes in the metal subframe of the hood and run them through there.
or you could do what alot of people do, just remove them.
Old Aug 11, 2005 | 12:36 PM
AbitAvenger's Avatar
Default Re: (-Gambit-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gambit- &raquo;</TD></TR><TR><TD CLASS="quote">or you could do what alot of people do, just remove them. </TD></TR></TABLE>
Old Aug 11, 2005 | 10:31 PM
Ax3l's Avatar
Nah, i need em.
Is it possible to make a system like the ITR has? With hidden nozzles?
Old Aug 12, 2005 | 12:44 AM
JDMlyfestyle's Avatar
move the window washer nozzels to the wiper panel shouldnt be that hard
dadeboy1
Paint and Body
Aug 19, 2007 03:14 PM
.Grimace
Sep 25, 2006 10:25 PM
da9pwnsu
Sep 22, 2006 11:33 PM
c0nspire
13
Aug 8, 2006 11:18 PM
BLUE EH3
Mar 4, 2006 02:35 PM
