ignition problems?
Old Aug 5, 2005 | 09:24 AM
91DroppedHatch's Avatar
Default ignition problems?
im just wondering if anyone knows whats wrong, i have a 90 hatch with a zc and when i turn the key nothing works, the radio, the headlights, and the inside lights dont work. i checked the battery and the fuses and there all fine so if anyone knows please help, alos the car wont turn over or anything.
Old Aug 5, 2005 | 12:33 PM
Default Re: ignition problems? (SloS13)
ok, i bought the car a couple of days ago and it all was fine, it came with the swap. the later on the CEL turned on, also the little gray box in the upper right corner of the hood has like a part that braches off and is connected to a wire harness, that part snapped but im not thinking its anything because the metal part is touching plastic so i figure its nothing. Also, I did get my car running again for a second and when i did i tried to turn on the headlights and when i did **** started buggin out then it shut off again. I got the car to run again by moving the snapped part to the ignition box around so im thinking its somthing around there, the ECU was throwing a code with 8 blinks so im gunna check on that.
Old Aug 5, 2005 | 12:49 PM
plz help
Old Aug 5, 2005 | 04:44 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: (91DroppedHatch)
Main relay?
patrickstar
Sep 1, 2009 06:34 PM
greenmachine22
May 30, 2008 12:59 PM
x4thGenCafe
Jan 5, 2008 08:54 PM
91DroppedHatch
Aug 5, 2005 04:41 PM
