Y8 Intake Manifold
Old Aug 5, 2005 | 08:36 AM
Skinflute22's Avatar
Default Y8 Intake Manifold
what is required to put a Y8 Intake Manifold and TB on my D16A6 and will it be worth it... will i notice improved performance
Old Aug 5, 2005 | 08:40 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Y8 Intake Manifold (Skinflute22)
http://www.geocities.com/joeyp....html
head there I did it helped a bit when I had a D
Old Aug 5, 2005 | 10:09 AM
vegaskurt's Avatar
Default Re: Y8 Intake Manifold (Ace$nyper)
I used the y8 manifold, tb, injectors and fuel rail when I did my mpfi swap. My d15b2 actually feels like it has power now. I definitly recomend it.
In a nut shell you just have to mount the IAT to your intake pipe, if you have an aftermarket one its cake. Then you can either use the MAP on the y8 tb or keep using your firewall one. I noticed no difference in using either so I got rid of the firewall one and I am just using the y8 one now.
Old Aug 5, 2005 | 10:33 AM
B--RYAN's Avatar
Default Re: Y8 Intake Manifold (vegaskurt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">I used the y8 manifold, tb, injectors and fuel rail when I did my mpfi swap. My d15b2 actually feels like it has power now. I definitly recomend it.
In a nut shell you just have to mount the IAT to your intake pipe, if you have an aftermarket one its cake. Then you can either use the MAP on the y8 tb or keep using your firewall one. I noticed no difference in using either so I got rid of the firewall one and I am just using the y8 one now.</TD></TR></TABLE>
zach1288
Mar 27, 2010 03:16 PM
kmeng
Feb 26, 2009 12:42 PM
jdmkid_82
Nov 25, 2008 06:19 AM
tobe1424
Jan 19, 2006 09:14 AM
