Suspension & Brakes Theory, alignment, spring rates....
Beak ITR Swaybar kit installation questions.
Old Aug 5, 2005 | 06:34 AM
GetawayInMoscow's Avatar
Default Beak ITR Swaybar kit installation questions.
Well I have my rear suspension off so I figure this would be a good time to install my Beak kit. The problem is, the instructions really don't make sense.
I saw a picture of how to set up the part that bolts onto the subframe. The problem I have with this is, where you bolt it on has a raised end, so there is no way to make the mount sit flush against the subframe. I think I must be missing something...
Old Aug 5, 2005 | 12:25 PM
Sukii's Avatar
Default Re: Beak ITR Swaybar kit installation questions. (GetawayInMoscow)
Did you already get the existing tach welded nuts off on the back? If you didn't, you need to do that in order for the brackets to sit flush with the subframe.
P.S. - Btw, there are ton of threads that show how to install the ITR sway bar with beaks kit, just search them, they are very helpful and will guide you through the process. Good luck
Old Aug 5, 2005 | 12:56 PM
Default Re: Beak ITR Swaybar kit installation questions. (Sukii)
Nevermind, I get it now. God Im an idiot.
slateEKsi
Jun 7, 2015 10:20 AM
deckster333
13
Feb 26, 2007 11:20 AM
ctownintegra
Suspension & Brakes
May 16, 2006 11:30 AM
TurboBumblBee
Mar 31, 2003 10:10 PM
Nighthawk GS-R
Oct 3, 2001 10:50 AM
