vtec killer cams?
Old Feb 20, 2002 | 05:18 PM
tecnic1's Avatar
Default vtec killer cams?
this guy is a screwball.
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1806367047
Old Feb 20, 2002 | 05:26 PM
MugenDC2R's Avatar
Default Re: vtec killer cams? (tecnic1)
Those aren't even TODA cams, the TODA vtec killer cams have the non-vtec lobes, but no VTEC lobe. The cams this guy's selling have one big *** VTEC lobe only. He's on crack.
[Modified by MugenDC2R, 6:26 PM 2/20/2002]
Old Feb 20, 2002 | 05:35 PM
tecnic1's Avatar
Default Re: vtec killer cams? (MugenDC2R)
those don't even look like honda cams.
Old Feb 20, 2002 | 05:44 PM
mugenr#1011's Avatar
what a dumbass
Old Feb 20, 2002 | 05:53 PM
hybrider's Avatar
Default Re: vtec killer cams? (mugenr#1011)
how do we go about reporting this bastid.....
Old Feb 20, 2002 | 06:09 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: vtec killer cams? (hybrider93)
FYI - real VTEC Killer cams:
Crap cams:
[Modified by itr009, 10:10 PM 2/20/2002]
Old Feb 20, 2002 | 06:25 PM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
While we're on the topic, does anyone run these cams, and are they any good? Anyone know HP added and price of them.
Old Feb 20, 2002 | 06:36 PM
B2FiNiTY's Avatar
Default Re: vtec killer cams? (itr009)
Crap cams:
Big difference.
Old Feb 20, 2002 | 07:17 PM
TypeR 599's Avatar
Default Re: vtec killer cams? (B2FiNiTY)
fug...i have no clue how you guys can tell a difference. they all look the same...well i'm glad you guys can tell coz when it comes time for me to buy some, i'll check with you guys to see if its good
Old Feb 20, 2002 | 07:22 PM
slowerthanu's Avatar
New User
Default Re: vtec killer cams? (TypeR 599)
The VTEC killer Toda Cams are a race only item and they will not idle well.
Old Feb 20, 2002 | 07:24 PM
Splat's Avatar
Hmm. I take that back. I wonder if they would operate as if VTEC was engaged all the time?
At any rate, they are not Toda VTEC Killer cams. That much is obvious. But what are they? Hmm!
[Modified by itr009, 11:26 PM 2/20/2002]
Old Feb 20, 2002 | 07:44 PM
Robster's Avatar
the concept of a vtec killer cam is stupid anyway, a lobe the size of the one they use could be used on an actual vtec lobe and a normal lobe for the small lobe, this way if the motor and vtec engagement are tuned properly, you'll get the broadest torque band possible from 2 different lobes.
Old Feb 20, 2002 | 07:47 PM
primoEF's Avatar
If you use killer cams just like having a non-vtec motor
Old Feb 20, 2002 | 07:48 PM
Stock R's Avatar
Default Re: vtec killer cams? (Robster)
they are not supid. those are for race cars... race cars will probbaly rarely go below 7k rpm. there is no need for the 2 small lobes and then the vtec. all they need is one small lobe for the low end and the huge one up top. that's where they need the power. without the vtec system, the valvetrain is lightened and they can revv higher safely.
Old Feb 20, 2002 | 07:56 PM
GokuSSJ4's Avatar
Default Re: vtec killer cams? (Stock R)
i know some one that had those cams for race only and , well to created the power neede out of the cams he needed to bump his CR way up high , he decided that the spec C are better !
Old Feb 20, 2002 | 08:34 PM
Splat's Avatar
Default Re: vtec killer cams? (Spoon1)
Spec C's like high compression as well - ask Jason (fastasknutz)
Old Feb 21, 2002 | 05:31 AM
Lip's Avatar
Lip
http://www.todaracing.com/cars.html
the last car on this page uses them(the one below mine).
have you held a killer cam in hand? they are light as *****...hollow
feel free to read this http://www.todaracing.com/B162.html
Old Feb 21, 2002 | 07:02 AM
TypeR0149's Avatar
Default Re: vtec killer cams? (Lip)
feel free to read this <A HREF="http://www.todaracing.com/B162.html" TARGET="_blank">http://www.todaracing.com/B162.html</A>
thanks Jeff that explained alot. people complain about Spec B's IDLE imagine these.
Old Feb 21, 2002 | 07:12 AM
Mike K's Avatar
Default Re: vtec killer cams? (Vegeta)
mike, did you really buy those spec B's?
call me today.
Old Feb 21, 2002 | 07:22 AM
IMPORTdrag's Avatar
why that heck would you want vtec on at all times? the vtec motor was designed to run vtec @ a certain rpm. those look like toyota cams. they only have 4 lobes. (from what I can see) [IMG][/IMG]
Old Feb 21, 2002 | 07:24 AM
Splat's Avatar
Default Re: vtec killer cams? (IMPORTdrag)
Spec B non-VTEC lobes ~= ITR stock VTEC lobes
Old Feb 21, 2002 | 07:31 AM
Mike K's Avatar
ok, if that's true... then how come nobody rocks like a 2000rpm VTEC point on ITR cams?
Old Feb 21, 2002 | 07:34 AM
Lip's Avatar
Lip
SPEC B
250 (11.0) - 295 (12.0) - 250 (11.0) IN
250 (11.0) - 285 (12.0) - 250 (11.0) EX
Old Feb 21, 2002 | 07:40 AM
Black R's Avatar
25 Year Member
Default Re: vtec killer cams? (Mike K)
mileage.
Old Feb 21, 2002 | 07:56 AM
Black R's Avatar
25 Year Member
I don't think you can get the real toda vtec killer to idle under 2-5k rpms.....
NOT STREETABLE, period.
