~~~~****HKS SSQ BOV inserts********
Old Aug 4, 2005 | 10:51 PM
slotec's Avatar
Default ~~~~****HKS SSQ BOV inserts********
anyone know the exact way on how to remove the inserts to put in a new one. need to know because im taking out my purple insert for a gold insert
Old Aug 4, 2005 | 11:23 PM
quik sol's Avatar
Default Re: ~~~~****HKS SSQ BOV inserts******** (slotec)
subscribing cause im interested to.
Old Aug 5, 2005 | 06:01 AM
Doodoo's Avatar
If you look straight into the BOV there are 4 hex head screws. Unscrew them and the enitre silver cap/front piece comes off. Thats it.
Old Aug 5, 2005 | 06:43 AM
ash.zero's Avatar
what's the diff in sound?
Old Aug 5, 2005 | 07:09 AM
theEGkid's Avatar
Yea what is the diffrence? im interested
Old Aug 5, 2005 | 07:12 AM
slotec's Avatar
Default Re: (SmoothlilHatch)
it says the purple is standard low frequency sound and gold is louder. my purple insert now sounds pretty loud like a greddy type S.
Old Aug 5, 2005 | 08:46 AM
Boofster's Avatar
Default Re: (slotec)
Doesn't it come with the purple one?
Let us know how it sounds. These are $25 and may be fun to toy around with
Old Aug 5, 2005 | 09:39 AM
slotec's Avatar
Default Re: (Boofster)
yea it comes with a purple and i ordered a gold for 25. i didnt see 4 hex bolts i see like 8 or 9 hex bolts
Old Aug 5, 2005 | 09:52 AM
Doodoo's Avatar
Only 4 come out from what I remember. Just test them until they loosen.
Old Aug 5, 2005 | 09:55 AM
slotec's Avatar
Default Re: (Doodoo)
dang i hope the insert has instructions with it
Old Aug 6, 2005 | 08:58 PM
Sketch_hs's Avatar
what if you take it out can you run no insert how does that sound
Old Aug 6, 2005 | 10:03 PM
red_crx's Avatar
Default Re: (Sketch_hs)
how many different inserts are there?
Old Aug 6, 2005 | 10:09 PM
red_crx's Avatar
Default Re: (red_crx)
let us know how its sounds after you switch them
Old Aug 7, 2005 | 08:31 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec &raquo;</TD></TR><TR><TD CLASS="quote">yea it comes with a purple and i ordered a gold for 25. i didnt see 4 hex bolts i see like 8 or 9 hex bolts</TD></TR></TABLE>
Your purple one uses all of the 8 hex bolts to hold in the valve suppressor a bit more tightly for a higher piercing sound. When you switch to the Gold one, it uses only 4 of the SMALLER hex bolt openings. It says it (though in Japanese) on the instructions that come with it. The 8 hex screws remove the outer housing.
The sound to me is a bit more "Professional" and not as high piercing. It sounds great after 14psi, but with less pressure, it's much quieter.
Old Aug 7, 2005 | 08:32 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">what if you take it out can you run no insert how does that sound</TD></TR></TABLE>
Tried it. With no insert or outer housing the Valve only sees like 2 psi, then it becomes a pressure leak. You can't hold boost without it.
Old Aug 7, 2005 | 10:14 AM
red_crx's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
The sound to me is a bit more "Professional" and not as high piercing. It sounds great after 14psi, but with less pressure, it's much quieter.</TD></TR></TABLE>
do you have any sound clips with the gold insert?
Old Aug 7, 2005 | 10:42 AM
Rod.'s Avatar
i didnt really notice that much of a difference. I would of put that money somewhere else
Old Aug 7, 2005 | 12:41 PM
TheShodan's Avatar
Moderator
I have a vid clip, unfortunately I haven't had the time to convert it and have it hosted..
Old Aug 7, 2005 | 02:52 PM
Sketch_hs's Avatar
i want to hear it!
Can anyone tell me why it sounds so different on my car VS. what i have heard on evo?
Old Aug 7, 2005 | 04:50 PM
turboteg2nv's Avatar
^^^Because your a ricer. haha
Old Aug 7, 2005 | 11:51 PM
NastyHabitzCRX's Avatar
the gold insert= turbo bling. the silver insert is the same which comes on them from the start.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
The sound to me is a bit more "Professional" and not as high piercing. It sounds great after 14psi, but with less pressure, it's much quieter.</TD></TR></TABLE>how is that so? they are all installed the same and the HKS squeal is louder on the gold and silver inserts than the purple one
Old Aug 8, 2005 | 12:15 PM
Sketch_hs's Avatar
Default Re: (turboteg2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv &raquo;</TD></TR><TR><TD CLASS="quote">^^^Because your a ricer. haha </TD></TR></TABLE>
damn '04 member!!
really it sounds completely different on the evo, much better on the evo. Is it because of the low boost? 6 vs 20 psi?
What do you guys set the spring tension too?
Old Aug 8, 2005 | 12:20 PM
DragSource's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec &raquo;</TD></TR><TR><TD CLASS="quote">it says the purple is standard low frequency sound and gold is louder. my purple insert now sounds pretty loud like a greddy type S. </TD></TR></TABLE>
Wait a minute...
You purchased a HKS BOV, only to spend more money to make it sound like the less expensive Greddy Type-S?
Or am I misunderstanding the purpose of these inserts?
Old Aug 8, 2005 | 01:00 PM
slotec's Avatar
Default Re: (DragSource)
i read up and it says that the gold is louder pitch than the purple and stock insert. The gold insert is liek an upgrade fromt he standard purple that comes in all the hks ssqv
Old Aug 8, 2005 | 01:04 PM
TheShodan's Avatar
Moderator
Default Re: (NastyHabitzCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX &raquo;</TD></TR><TR><TD CLASS="quote">the gold insert= turbo bling. the silver insert is the same which comes on them from the start.how is that so? they are all installed the same and the HKS squeal is louder on the gold and silver inserts than the purple one
Look at the instructions closely. The silver insert( The way it came in the universal application in the box) has all 8 screws being used to hold the diaphram in. If you notice on the instructions........ only the 4 smaller holes are used to hold in the gold, to change the sound pitch. (See how it only shows 4 holes being used......)
If you look at the 2 inserts together, one is SLIGHTLY (look closely now) thinner on the Upper "triangle" than the other. this is what makes the sound slightly different.
