big brake problems!!
Old Feb 20, 2002 | 05:15 PM
Renntech C230's Avatar
Default big brake problems!!
ok i just finished my b16 swap into my crx and it works perfectly...well i thought... my barkes dont work at all !!!!! we switched the hf brakes to si brakes and that was no big deal. we have bled the brakes twice and nothing is leaking when we tighten them back down. plenty of fluid in resivour. it isnt a simple problem cause we would of figured that out. how about vaccum lines problem on the brakes anyone had a problem with that on a crx. you know how it has that brake assist??? help please.
derek
Old Feb 20, 2002 | 07:21 PM
SiR Kid's Avatar
New User
Default Re: big brake problems!! (b16hfderek)
make sure the big vacuum line on the firewall on the driver side is hooked up...
If it is, then rebleed the whole system in this order: rr,lr,rf,lf.
Bleeding means to leak down the brakes til NO AIR is present, not just pump it up, open valve, close valve, repeat 3 or 4 times.
When swapping the front brakes, ALOT of air probably got into the brake lines, front and back.
Old Feb 21, 2002 | 06:00 AM
Default Re: big brake problems!! (SiR Kid)
cool i will try that tonight i only bled them one time and i think i did do it in that order.
jdmjoka
Dec 16, 2008 06:31 PM
m3 mark
Apr 21, 2008 06:17 PM
benson03
Feb 20, 2006 09:05 AM
bOOsTiNSoHcVtEc
May 11, 2004 12:55 PM
mickey513
Dec 2, 2003 07:53 AM
