b16 swap radiator problem
Old Aug 4, 2005 | 09:36 PM
crx90rcr's Avatar
Default b16 swap radiator problem
i have a d15 radiator in my car and the diameter of the pipe is smaller then the diameter of the pipe coming out of the block so what do i do get a new radiator basicly or is there any way to ghetto rig it 4 now that u diy honda tech people can think of
Old Aug 4, 2005 | 09:38 PM
HondaEF8R's Avatar
Default Re: b16 swap radiator problem (crx90rcr)
just go buy a new one its easyer like that
Old Aug 4, 2005 | 09:41 PM
crx90rcr's Avatar
Default Re: b16 swap radiator problem (HondaEF8R)
i figured that
Old Aug 4, 2005 | 10:15 PM
BlueShadow's Avatar
Default Re: b16 swap radiator problem (eda6)
You can also use a piece of radiator hose or one of those rubber sleeves on the radaitor hose to make a shim. Wrap that around the radiator neck which are too small and use the Teg radaitor hose and slip it over the shims and clamp down.
Old Aug 5, 2005 | 06:32 AM
crx90rcr's Avatar
Default Re: b16 swap radiator problem (BlueShadow)
o ok so basicly use part of the old radiator hose as and then slip the new one over ok brb trying idea
Old Aug 5, 2005 | 02:03 PM
crx90rcr's Avatar
that is one of the most ghetto fabulous things ive ever done it reminded me of brandons end tanks on his inter cooler
Old Aug 5, 2005 | 02:49 PM
Eaglekper0046's Avatar
I used 86 accord up rad hose cut to fit and 91 crx si lower hose. I just had to force it over the water necks. No leaks for 5 yrs now. Its the cheapest and the most reliable
dcraige
Jun 24, 2010 07:43 PM
streetracerof06
Feb 13, 2006 01:14 PM
hybridevul
Jun 16, 2005 07:03 AM
lucasbkellner
10
Nov 15, 2004 04:13 PM
Chip398193
Sep 10, 2001 01:12 PM
