Quick Question PLEASE READ
Old Aug 4, 2005 | 09:34 PM
LurkerS8's Avatar
Default Quick Question PLEASE READ
I have a 88 crx HF model. I want to upgrade my front hub assembly to stronger axles like the crx si cuz I have a turbo zc. My question is if I buy 91 civic hb si Knuckles calibers with AEM pads and upper control arms will it fit? Would I need the lower control arm from the hb also or could I run the ones on my HF?
Old Aug 4, 2005 | 10:05 PM
Loki12's Avatar
Bump...Very Good Q
tyro's Avatar
Default Re: Quick Question PLEASE READ (LurkerS8)
Well..looking at the san leandro honda parts site, looks like your CRX LCAs are the same as any in the 88-91 models.
I'd be willing to bet the UCAs are also the same...prally all bolt right on!
-edit- check here: http://www.slhondaparts.com/browse.asp , open up both cars in difefrent windows/tabs and compare, it's fairly easy. FWIW, Both parts diagrams are identical.
Modified by sub-STD Hatch at 1:16 AM 8/5/2005
Old Aug 4, 2005 | 11:00 PM
LurkerS8's Avatar
Hmm that helps me out a little but I still need to know if the LCA will fit.
Old Aug 5, 2005 | 12:04 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: (LurkerS8)
I'm pretty sure it will.
Old Aug 5, 2005 | 12:13 AM
PURPLETERROR aka BIGMATT's Avatar
It will work fine, the upper and lower control arms are the same, the hub spline is the only difference.
Old Aug 5, 2005 | 08:28 AM
LurkerS8's Avatar
Sweet thanks a lot guys
i_VTEC
Suspension & Brakes
10
Jan 5, 2009 01:45 PM
janz3n
Mar 27, 2008 05:56 PM
jerkof1
Aug 20, 2005 05:24 PM
photonjedi808
Apr 7, 2003 08:20 PM
