Crx DX(MPFI) into D16A6 Running Rich and not getting spark!!!
Old Aug 4, 2005 | 07:32 PM
red91g2's Avatar
Default Crx DX(MPFI) into D16A6 Running Rich and not getting spark!!!
i have a 90 dx swapped to a d16a6 and with a working Ecu (tested i tested two different ecu by the way) its throwing code 13 Atmoshperic pressure sensor which is in the ecu... not working when swapped ecus and tested again.
well after the swap was done it ran but ran really rich which fouled the plugs after while and i swapped those and rechecked gapping and all, and now the car is not getting spark but tested each plug and all work, so im not sure what else has gone wrong when the old plugs fouled out and need some advice on what to check first so i dont spend an arm and a leg on parts i dont need.
Does anyone know what should be tested next and where i should go from here, any help would be greatly appreciated!! TIA
Old Aug 4, 2005 | 10:49 PM
UltimX's Avatar
Default Re: Crx DX(MPFI) into D16A6 Running Rich and not getting spark!!! (b18c93)
Fix ur atmospheric presure sensor problem
Old Aug 4, 2005 | 11:59 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: Crx DX(MPFI) into D16A6 Running Rich and not getting spark!!! (UltimX)
Check your timing too. and your fuel pressure.
Old Aug 7, 2005 | 07:52 PM
red91g2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">Fix ur atmospheric presure sensor problem</TD></TR></TABLE>
I cannot obviously figure out how to fix the sensor prroblem, because i replaced the ecu and the code is still there, the sensor is in the ecu btw, any more suggestions?
Old Aug 7, 2005 | 08:20 PM
UltimX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c93 &raquo;</TD></TR><TR><TD CLASS="quote">
I cannot obviously figure out how to fix the sensor prroblem, because i replaced the ecu and the code is still there, the sensor is in the ecu btw, any more suggestions?</TD></TR></TABLE>
No it isn't. It is a sensor. Get a helms.
JDM_EK4_Coupe
Apr 24, 2007 07:28 PM
dustinO
Oct 4, 2006 01:50 PM
Si_chRis
May 19, 2006 08:19 AM
MugenFlaredCRX
Dec 20, 2005 08:38 PM
barry11j
12
Sep 29, 2004 08:47 PM
