which ecu to use???
my friend was thinkin about goin B16. i got a good question... lots of debates from others so i thought id get some opinions from people who have actually tried this...
if you run a b16 swap... can you use a gsr ecu of the same year? would it make a difference if he went LSVTEC and used a gsr ecu instead of the b16 ecu?
[Modified by dlplayboy, 4:31 PM 2/20/2002]
he can use the ecu...but it's not the best set up. I'd just get a reprogrammed P28.
Remember, you must match the year of the car when getting an ecu, not the motor.
