b18 in 93 hatch smokes blue smoke when warm
Old Aug 4, 2005 | 04:20 PM
LShatchie's Avatar
Default b18 in 93 hatch smokes blue smoke when warm
my motor doesnt start smoking until it is fully warm and after driving for a bit, is it the piston rings or seals? pulling the head tonight if its the seals.... thanks
Ok just performed a compression test and here are the results...
Cyl. 1 = 190 psi
Cyl. 2 = 190 psi
Cyl. 3 = 195 psi
Cyl. 4 = 200 psi
Modified by LShatchie at 5:15 AM 8/6/2005
Old Aug 4, 2005 | 04:58 PM
ef-hatchcrap's Avatar
Default Re: b18 in 93 hatch smokes blue smoke when warm (LShatchie)
Pistons rings are gone rebuild time
Old Aug 4, 2005 | 05:25 PM
scott92hatch's Avatar
rings blue=oil
white=coolant
black=rich
Old Aug 4, 2005 | 06:20 PM
LShatchie's Avatar
Default Re: b18 in 93 hatch smokes blue smoke when warm (scott92hatch)
ok i know what blue smoke means, i just want to know if its the rings or seals.... the car still has all of its power and drives fine, it just smokes
Old Aug 5, 2005 | 10:00 AM
LShatchie's Avatar
Old Aug 5, 2005 | 10:07 AM
jameskersten1's Avatar
not uncommon for a honda motor to have a fried oil ring but good compression rings.
Old Aug 5, 2005 | 10:10 AM
LShatchie's Avatar
Default Re: b18 in 93 hatch smokes blue smoke when warm (jameskersten1)
so doing a compression test isnt going to help to much?
Old Aug 5, 2005 | 10:23 AM
komat's Avatar
you need to do a leakdown test for a better result
Old Aug 5, 2005 | 10:48 AM
LShatchie's Avatar
Default Re: b18 in 93 hatch smokes blue smoke when warm (komat)
how exactly is a leak down test performed?
Old Aug 5, 2005 | 05:59 PM
LShatchie's Avatar
Cyl. 1 = 190 psi
Cyl. 2 = 190 psi
Cyl. 3 = 195 psi
Cyl. 4 = 200 psi
This is on a b18a1... does this information help any?
I myself think its the valve seals, because if it were the piston rings wouldnt it smoke all the time? I just dont want to pull the head and replace the valve seals when it could be something else. I just need some backup info before I do anything drastic.
Old Aug 5, 2005 | 06:49 PM
LShatchie's Avatar
Old Aug 5, 2005 | 08:01 PM
FortunateFool.'s Avatar
PCV Valve ??? Doubt it but eh ..Worth a shot
Old Aug 5, 2005 | 11:51 PM
LShatchie's Avatar
Default Re: b18 in 93 hatch smokes blue smoke when warm (FortunateFool.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FortunateFool. &raquo;</TD></TR><TR><TD CLASS="quote">PCV Valve ??? Doubt it but eh ..Worth a shot</TD></TR></TABLE>
what exactly do you mean?
Old Aug 6, 2005 | 12:43 AM
LShatchie's Avatar
just checked the pcv valve out and it seems fine, so i dont think that it is the problem
Old Aug 6, 2005 | 01:00 AM
Stoich EG2's Avatar
Default Re: (LShatchie)
<U>Do a leakdown test.</U> it will possibly determine where you are burning oil from. but since you do have good numbers across the board, i'd say your valve seals
Old Aug 6, 2005 | 01:13 AM
LShatchie's Avatar
Default Re: (ADVAN EG2)
i dont have the time or the money to waste to do a leakdown test right now... im just guna replace the valve seals and hope that what it was
Old Aug 6, 2005 | 10:47 AM
Stoich EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">i dont have the time or the money to waste to do a leakdown test right now... im just guna replace the valve seals and hope that what it was </TD></TR></TABLE>
then why bother asking us? do you know what a leak down test is? it can be done for little to no money. good luck replacing your valve seals.
Old Aug 6, 2005 | 11:36 AM
LShatchie's Avatar
well if you knoticed, i already asked that question a few posts up ....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">how exactly is a leak down test performed?</TD></TR></TABLE>
its so hard to get some help on HT anymore...
Old Aug 6, 2005 | 03:56 PM
Magick211's Avatar
Basically the cylinder is filled with compressed air and you have a guage hooked up to the line and see how much leaks trough.
Thats what i found out by browsing trough a few threads
Old Aug 9, 2005 | 12:20 PM
LShatchie's Avatar
Default Re: (Magick211)
Ok well i didnt do the leak down test, I just took the head off and took it to a machine shop by me. They are going to inspect it first to see if the guides were bad or if the seals got hard/cracked, then they are going to call me back. The pistons look pretty good they dont really have much carbon on them, just dark from all the miles and over the years. All 4 cylinders still have the factory cross hatching too.
Old Aug 9, 2005 | 12:22 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
on old motors, you might get some white smoke at high rpms, but it looks like your rings are shot
you can run it for a while, if you don't beat on it
Old Aug 9, 2005 | 12:26 PM
LShatchie's Avatar
Default Re: (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">on old motors, you might get some white smoke at high rpms, but it looks like your rings are shot
you can run it for a while, if you don't beat on it</TD></TR></TABLE>
Why would my rings be shot? I dont understand....this motor only has 75k on it, just from sitting for a year and a half?
Edit: The motor came from my friends friend's 93 integra LS with 75k, the teg was totaled so my friend scooped it up for a good price and he had it in his garage for about a year sitting there because he was planing on building it and boosting it, until I decided to buy it and it sat for another 6 months.
Old Aug 9, 2005 | 12:32 PM
philosofy1's Avatar
your pcv valve may look fine but it might be frozen on the inside. had the same problem, spent $3 on a pcv valve and the problem was solved(b16a motor only had alittle over 50,000mi on it.).
Old Aug 9, 2005 | 12:33 PM
LShatchie's Avatar
Default Re: b18 in 93 hatch smokes blue smoke when warm (philosofy1)
the pcv valve is only like a year old, and I tested it and was fine...
Old Aug 9, 2005 | 12:34 PM
LShatchie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">you can run it for a while, if you don't beat on it</TD></TR></TABLE>
are you talking about how it doesnt smoke for a little while?
