Help! Motor Swap... turning to bad. Need help!
I bought a 1993 Honda Prelude with 187K miles on the chasi and 80K miles on the rebuilt motor. I had it for a week, then the motor blew. So I took it in to an engine shop to have the motor rebuilt again. They replaced everything, block, pistons, cranks, etc etc. They've had it for over 3 1/2 weeks now, which should have only took 7-10 days. As of last Tuesday they installed the motor. And now today(Thursday) they said there might be a problem with the ecu, because the electronics isnt working right. I have already invested $4200 in the motor and installation, and if the ecu is bad they said its going to be another $400. By the way its an H23. Has anyone ran into problems like this? Any info can help, thanks.
yes, but I guess its due to labor, and the fact that its a shop in Arizona. They were charging 3800 for a motor rebuild WITHOUT the block, and I had to add another 400 for the block. Now they said I might have a bad ecu.. then they will charge me 400 for that.
Yea, well there arent to many engine shops down here, if they tell us that they cant fix the problem then Ill take it to somewhere else. btw, how much are you selling your r33 taillights the fil?
