Apexi N1 Coilovers
Old Feb 20, 2002 | 03:07 PM
Rhetoric's Avatar
Default Apexi N1 Coilovers
How are these compared to Tein Ha's? Does anyone have the specs on the N1's?
Old Feb 20, 2002 | 03:59 PM
bhcvc's Avatar
Default Re: Apexi N1 Coilovers (G S R)
Are you talking about the 00spec version or the 99spec version? I have the 99spec for my civic and I like them a lot. They're very street friendly, so they're not too aggressively valved. the spring rates are F=9kg/mm R=5kg/mm. I'm not sure if it's the same rate for the tegs, but it won't be too far off from that even if it's different. The damper has 13 valving adjustments. However, adjusting the damping's not intuitive (there's no dial and the clicks are hard to feel). And even tho there's only 13 adjustments, the thing clicks about 44 times. All in all, they were a great deal for me and I believe are made of aluminum, which is lighter and more rust resistant than standard steel. I'm selling mine (virtually brand new, only used them for 3 weeks), but they won't fit tegs unless you want to shave a lil bit of material off your lca's. HTH.
Old Feb 20, 2002 | 04:12 PM
SuperTwinz's Avatar
the tein has are good all around...the apex n1s need stiffer springs and rebuildable
jeison
Apr 22, 2007 04:21 PM
YTYPER
Jul 7, 2006 03:14 PM
jed1717
Suspension & Brakes
Jan 6, 2006 11:07 AM
ITRFetish2000
May 25, 2004 05:41 PM
d0nkeyxPunch
Jul 30, 2001 07:23 AM
